Garage > Studio conversion. Any tips, valuable experience?
Bob_GnarlyBob_Gnarly Frets: 139
edited October 2018 in Studio & Recording
I have a tandem garage (i.e. single width, double length garage) and am about to convert the back half into a guitar/recording studio.
My wife is insisting, rightly so, that it is thouroughly soundproofed and I am looking at using a floating stud partition and walls with rock wool insulation to achieve this. A major expense will be the requirement for two large windows which will need to be sound insulating as the back half of the garage has two single glazed windows currently.
I'm sure it will be great once complete, but would be interested in any tips, experience from others who have done this conversion.
P.S. I won't be doing the work myself, we are getting a new kitchen put in and getting this done at the same time by a reputable joiner.
Cheers
Barry
  • The studio will be from the post next to the light switches back.
  • JalapenoJalapeno Frets: 6378
    There's a superb YouTube HowTo
    Feedback
  • There's loads of info on the Sound on Sound forum.
    I went with a room within a room, stud as you're planning. Double layers of acoustic plasterboard and green glue between the layers.
    If you can a second interior door air lock styley is worth doing.
  • spark240spark240 Frets: 2073
    You can get sound block boards .....I use Rockwool Flexi for insulation.
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • FunkfingersFunkfingers Frets: 14320
    +1 for Paul White and Hugh Robjohns.
    What will be the dimensions of the finished working space? Also, where is that fridge/freezer going to go? (You will not want that on the same mains supply as the recording equipment.)
    Be seeing you.
  • Thanks, will check out some You Tube vids and have had a nose in the SOS forum. Lots of good stuff.
    Funkfingers, that is an old pic from before I moved in. Had a complete rewire since then with the garage on a seperate ring, and no fridge/freezer.
    no fridge/freezer.
    In that case, where are the musicians' refreshments going to go? ;)
    Be seeing you.
