I’ve been doing quite a bit of recording recently and think a 12 string might be useful to have to hand, for some of the things I’ve been working on. I’ve recently played a second hand mahogany Martin American built jumbo which was very nice - but had bellying top/neck alignment issues, which ruled it out. I also played a new Taylor 150e a while ago - which from memory sounded decent - but at £750 struck me as expensive for a Mexican/laminated wood guitar.
I’m fine with buying used - and don’t really care about the country of origin. Any recommendations?
Yes, I'm really serious.
They're not expensive - £250 would buy you the best one in the world, and you can often find them for around half that - and although they don't sound 'great', they do have a nice vintage plywood character. Most importantly, because they have an adjustable bridge saddle and a bolt-on neck (and a zero fret, which also helps), they can be set up to play really well, which for an 'occasional' 12-string player is a huge advantage.
On a recording, just the fact that it sounds like a 12-string is what really matters - the quality of the guitar is less important than with a 6-string, it's the jangly overtones which make it sound good rather than the depth of the sound or the responsiveness.
Yes - I was looking at a Danelectro at the Manchester Guitar Show last Sunday - I’ve not ruled the idea out.
Funnily enough, the shop with the Martin has one in stock - I’ll give it a try next time I’m nearby.
Thanks for the suggestions.
If so, don't... 12-strings were always originally intended to be tuned lower, D-D or even below that - Leo Kottke used C#-C# or C-C and Leadbelly as low as B-B, although light strings didn't exist back in his day. You'll find it sounds a lot better as well as being easier to play. If you want to play in the same keys as normal, capo back up to E.
I keep my Martin in D-D with 10s, which is roughly equivalent to 12s in E-E on a 6-string.
Id also suggest looking at a Simon & Patrick Cedar 12. I had one of those too. Best sounding acoustic I’ve ever played. Unfortunately I’m not a huge guy & it felt like I was playing a wardrobe! But it did sound epic.
I’d recommend tuning down a step too. Stick a capo on it and it’ll make for easier playing. Also I always manage to bust the D octave string when I try to tune to E-E.
It could well work better as a layer over a normal 6 string tuning
Here's my 73 F412. Sounds like a grand piano.
http://imgur.com/Kd1dSOZ
http://imgur.com/zEKtH3p
it's supposed to be a better version of the effect using a 12 string, and without having to buy a new guitar
http://www.daddario.com/Resources/JDCDAD/Videos/DAddario_Nashville_Tuning.pdf
As I understand it, a 12-string is really a studio instrument. The problem with using it live is that you would probably not want to play it on the whole song. You would more likely want to switch between 12 and 6 strings, which would require a guitar with two necks.
Another problem I believe is that the 12-string guitar has serious issues with neck tension, way beyond what you find with normal guitars.
Anyway, I am sure that fans of the 12-string will now leap to its defence.
I played mine exclusively for a couple of years. I preferred it to a 6 string for open mic nights as it sounded so full.
The increased string tension can cause structural issues- neck bow, bridge lifting & top raising.
However most modern 12s are designed to avoid this & have stronger necks & bridges plus extra bracing. My Vintage Brett 12 had a lower action & was easier to play than most of the other acoustic guitars I've had.
Restringing was a ball ache though.
Percussive slide on an open tuned 11 string anyone?
This guy isn't bad either
I'd agree with the suggestion that a decent inexpensive 12 is fine for playing and recording in the mix with other instruments. You'll get a fine result without breaking the bank. If you're playing unaccompanied, then a nicer instrument will be, well... nicer.
Having a 12 to noodle on can give rise to ideas you might not stumble across otherwise.
Perhaps a lifetime of tuning down a full step would have prevented these issues - and may prevent them from worsening in the future - but it’s certainly put me off buying an older one. I’m beginning to think a used Taylor 150e, which is largely of laminate construction - and has a bolt-on neck which makes resetting easier - might be the way to go.
