Magnetic Effects Sändare V2
Magnetic_EffectsMagnetic_Effects Frets: 135
edited October 2019 in Made in the UK tFB Trader
The Sändare is a dynamic, low to medium gain Overdrive and Booster that retains the tonal characteristics of your guitar and amp. The perfect choice if you like the sound of your guitar and amp and are looking for a pedal to add a bit of organic drive or push your amp naturally into breakup
The Voice control can be used to dial in the overall eq response of the pedal while the High and Low controls are flexible and well balanced with a musical response. The combination of the three controls enables the pedal to be configured for an even frequency response or tailored to your guitar and amp.
The pedal responds well to variation in pick attack and settings of your guitars volume control.
While the Sändare offers great Overdrive tones it also excels as a Booster. It stacks well and can provide a great sounding boost. An internal voltage double circuit converts the power up to 18V which allows for plenty of headroom.
Features:
Volume, Gain, Voice, High and Low controls
High input impedance and low output impedance
Voltage doubler for increased headroom
Top mounted Jacks and DC socket
True Bypass switching
9V DC centre negative adapter operation
http://www.magneticeffects.net/satellite/
