To redrill the neck you will drill out and plug the existing holes with side-cut maple plugs then redrill new ones, which is a much more difficult operation.
I'll drill the body and if needed fill the holes using the tooth pick technique.
When you say the outer two, do you mean the low e side screws?
You won't need to fill the neck screw holes in the body, they don't need to be tight. The alignment of the neck is set by the pocket not the screws, which is why 70s Fender with oversized neck pockets allow the neck to move about.
If it is the holes that are the problem, going up 1mm in diameter should fix it.
how would you alleviate the problem?
It was certainly less trouble to help than when someone brings me a kit they haven't assembled right and asks me to do it .
Feel free to ask, it shouldn’t be too hard to solve.
