If/when you order a replacement block, make absolutely certain that it is drilled to fit the Metric MIM baseplate.
Another popular upgrade is the saddles. The stock MIM items are solid cast zinc. They might as well be cheese. The vintage style bent steel saddles yield the Fender sound. Solid saddles in superior materials should also be an improvement over stock. e.g. GraphTech String Savers. Again, make certain to order Metric with the narrower string spacing.
I thought the MIM standard Strat had bent steel saddles? I'm sure the later ones did.
Regarding the nut and string tree, I love a nice bone nut but if the existing one isn't causing problems I'd leave well alone. Likewise string trees - if I need more break angle over the nut (e.g. G string) it just put an extra wind on the post (admittedly easier to judge with vintage Kluson style tuners).
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
Nomad
