Zilla Fatbaby Loaded 1X12, WITHDRAWN....Suhr Badger 30 Head SOLD....Dr Z Maz18NR Head SOLD
Zilla Fatbaby 1 x 12 (Open/Closed Back) Loaded. Celestion Heritage G12H (75) (30 Watt Speaker)
WITHDRAWN FROM SALE DUE TO SELLING OFF MY BOGNER RIG.
£275
Dr Z Maz 18 Non Reverb Head....SOLD!
Sold to DCP (November 2020) for £850 (Buyer arranged/paid for shipping and insurance).
Innards: 3x12AX7's 2xEL84's and 5AR4 Rectifier Valve.
Fantastic sounding single channel amp, cosmetically immaculate and great working order. It's been gigged and transported, but well looked after. It comes in lovely Red Tolex.
This is the Non Reverb Head which does have a bit more gain than the reverb version. I'd say it does a tad more than AC/DC level gain. Amp is great as a clean pedal base, good Headroom for 18 watts with the Master Volume.
The included Footswitch is a boost function. I have tried it but never used it for gigs, bit of a gimmick really as it boosts too much both gain and volume and there is no regulation of it, still, it came with the amp, so it is included.
Regardless of the FTSWTCH, there is a good amount of gain there, put a few pedals in front for different flavours. The variation of tones from the Amp are a winner, this is mostly down the the "Cut" control. Anecdotally noted for being able to go between Vox, Fender and Marshall tones. I can't vouch for the exact truth of that, but it covers tons of ground, it won't disappoint.
The clarity of the Amp is superb, even when pushed to overdrive, you can pick out every note of the chord. The EQ is very good on the amp. FX Loop is great.
The amp is 18 watts, but it's loud enough to break your ears, don't be fooled by that 18 watt rating. The stock Valves did need replacing around 130 - 150 hours. I'm positive it was no less than that, but that is an estimate. The Jewel light Bulb did need to be replaced too at some point.
The amp is now fitted with the Russian 16N4N Valves from Langrex which are recommended by the Dr himself as these amps can run hot.
Amp Comes with Roqsolid Padded Foam Cover which is in great condition.
Suhr Badger 30 Head, Mk 1 Version ..........SOLD.... to DPC of this Parish (in October 2020) for £825 (Buyer paid/arranged for shipping and insurance)
Thanks.
Only a Fool Would Say That.
http://www.peachguitars.com/guitar-amps/guitar-amps/dr-z-variable-boost-footswitch.htm
GLWTS.
That new footswitch idea was needed badly.
I recall you (Misty) gave me a lot of advice re the valves on these when a dodgy one went down on this. Karltone were really helpful too.
I'd need to be somewhere I wouldn't get arrested, hehe. Don't think I'll have the freedom to try those settings anytime soon. I like to set to..........................."Edge of break up" at gigs.
I know it's a great sounding amp and have experimented with the settings. I just have too many amps and am at critical mass with GAS for more Guitars.
Cheers.
I wholeheartedly believe this deal is the best way forward for any Guitarist, young or old, and I am positive that I will see it through.
I have solid support and acceptance, Forum-Wide, on the strength of this deal. It's simply not enough to consider a deal that is only beneficial to my Bank Account, but to consider one that can, through the power of tone, benefit our entire community.
No further comment at this time
Not a minute more I shall give thee. 23:59 is the time thou shalt recognise and the ending of the time shall be 23:59. The stroke of midnight I shall not count.
00:01 is Right Out!
If the time hath not been reached, then lobbeth thou cash at me and I shall, be grateful in thy sight and shall handeth over the Amp.
