Fender Mustang
AlbertCAlbertC Frets: 911
I’m interested in some views and opinions on Fender Mustangs – 1960/1970s rather than later re-issues.
Probably throw Duosonics in the mix as well.
I’m after an older guitar for mainly clean/cleanish tones
  • FunkfingersFunkfingers Frets: 14324
    Mustangs and Duo-Sonics certainly do clean tones. Of the two designs, I am biased towards the one with the fixed bridge.
    If you need greater output for overdriven sounds and are not fussy about vintage originality, it would be worth modifying the wiring to add the option to link both pickups in series. Alternatively, whack in a Hot Rails or Li'l 'bucker.
    Might be worth communicating with @HarrySeven about this.
    Be seeing you.
  • KoaKoa Frets: 120
    Don’t forget early Musicmasters too, I played a lovely ‘71 recently, nice original pearl guard. Never tried a Bronco so can’t comment but another flavour of short scale Mustang ish vibe I should think
  • grungebobgrungebob Frets: 3300
    I’ve owned and stupidly sold since two vintage musicmasters a 64 and a 67 I think it was. Both sounded wonderful.
  • AlbertCAlbertC Frets: 911
    I actually already have a 1963 Musicmaster but my thought process was sell that and get a twin pickup to give me a bit more versatility tonally.
  • gringopiggringopig Frets: 2648
    edited July 2020
    gringopig said:
    Interesting. Would you sell on here if so minded and at what price?
    Yes, I am definitely considering selling it on here. I have two electrics to sell and that will be one.
    I haven't decided on my selling price at the moment - I need to do a little homework but it will be a realistic.
    You can have a preview here - https://imgur.com/a/ms0h1Mt
    edited July 2020
  • I had a 68 Mustang that was great for clean tone.  I used it in a band in the mid 80's for a year or so plugged into a Fender Vibrolux Reverb amp.  Got the Dire Straits  sound down cold and wasn't bad for overdriven blues either.  I stopped gigging it because it was getting a bit beat up and worn out.    Someone mentioned a fixed bridge, mine had the vibrato bar and some kind of floating bridge that was a little problematic as it would move a little during hard playing and throw the intonation off.  Otherwise though, a great guitar.
    Hi. yes, very nice. It is an earlier model though with a slab board fingerboard. If you look at the end of the neck at the heel, you will see that the fingerboard joins the maple neck in a straight line rather than a curved veneer. I believe it will be a 1961 early 1962 model and these go for a premium over veneer fingerboard models.
    EDIT:
    Guitar Info
    Your guitar was made at the
    Fullerton Plant (Fender - Pre CBS Era), USA
    in 1962
    Production Number: 72361
    My 1964 Duo Sonic:
    Note the flat fingerboard line after the nut. My one is a veneer curved fretboard.
    Your one:
    The heel will look like this:
    Thanks. Actually this has jogged my memory - I think  I was getting my years mixed or mis-remembering and it’s actually ‘61 not  ‘63, which would presumably make sense with what your saying.
  • rexterrexter Frets: 369
    FWIW I am a lover of these guitars having started off my guitar obsession back in the mists of time (90s haha) with a Duosonic reissue. Have owned multiple vintage Mustangs since then and variations on the Musicmaster/Duo.
    To me they always feel like they play (and sound) better than the more expensive Jaguar, but, perhaps that's just personal as I can never bond with Jags... no matter how much i want to.
    Mustangs sound lovely clean, specially the neck+middle position. If you can pick up a late 60s one that needs a bit of tlc for a good price I reckon it's a good way to go. I had a 77 which was great, but the 60s bodies will be lighter normally as they are poplar rather than ash. Those vintage pickups sound lovely of course, but modern handwound offerings from the usual suspects are all pretty great too.
    Custom colours, vintage restorations, high end guitar finishing
    www.rexterguitars.co.uk
  • StuckfastStuckfast Frets: 2394
    Has anyone ever got a Mustang vibrato to work well? Mine will stay in tune for years at a time if you remove the arm and screw the trem system right down so that it jams on top of the strings, but if you actually try to use it as a vibrato it never returns to pitch properly.
  • JD50JD50 Frets: 651
    Yep I have an old USA Mustang stays in tune fine.
  • ICBMICBM Frets: 71963
    Yes, I have. You need to use reasonably heavy strings (probably at least 11s), set the bar as low as possible but with enough of a gap under the strings to allow it to move freely, and do the usual things with the nut and machineheads.
    I did a variation on this on a Squier VM Mustang. Its vibrato is a dirt cheap copy of the original. Since the arm was not going to be used, I rotated the tension bar so that the strings could be anchored through it instead of wrapping around and underneath.
    Be seeing you.
    Another one jumping in to say the Mustang vibrato is incredible when set up. Nothing shook the tuning on mine. A lot of unnecessary criticism for all the offset fender vibratos, the JM/Jag is also one of the best trem units in tersm of tuning stability and feel when set up right too.
    I bought  a Mustang VM last year and find  it  to be more stable.  I use 11's on all my solid bodies but I have one question about the trem bar.  I don't use it much, to the point that I hardly ever have it on the guitar but when it's on it rides a little higher away from the strings than I would like.  I've not spent the time researching, or worrying about it but is there an adjustment I can make in regards to this?  Otherwise I'm very impressed with this guitar.
