FS Laney Cub 8 with built in attenuator
Great little amp this, does the break up thing nicely at home use volumes.
I have installed an L-pad type attenuator in line with the speaker... this allows for cranked sounds at any volume, or you can dial it out of the circuit completely to play the amp as it would be stock.
Only issue with this one is the power light works intermittently, but it otherwise is in great condition.
Upgraded with Ruby valves.
Asking for £75.
Collection from Bristol preferred but could post at cost.
1979 Tokai TE-85
1980 Tokai LS-80
