So... I'm in the middle of nowhere and I've just snapped the e string on my strat at the ball end.
The string is long enough to be re-strung (just) but it's no longer attached to the ball end which obviously stops it in the bridge. Any ideas on how I can re-string it so it'll last a few days?!
Before you laugh... I'm not so impoverished I can't afford strings. I can! The problem is I have 5 more days to go until I can get some (Got loads of sets at home)! Pissed off as it was a new set!
Help/suggestions appreciated! It's a long shot!
Restring and hope.
(I was a skint student once).
Couldn't afford strings. So learnt to play without it.. Still play without it.. To used to playing without it to be bothered aha.
I've knotted the end of strings through the ball end before, just make sure you leave enough for the post.
The fix!
