Compression vs Sag
matt1973matt1973 Frets: 386
edited January 2019 in Amps
Compression and sag - obviously a key aspect of any rig but I, probably like many, have not given it much thought and have only really engaged it by experimentation, feel and knob-tweaking. So whilst both reduce dynamic range aside (one from a stomp box and via a power amp characteristic) would anyone care to explain the difference between the two things?
Whilst we're at it I would also be interested to hear arguments for and against compression/sag in certain music contexts and how individuals utilise and employed it within a rig.
  • darthed1981darthed1981 Frets: 11754
    I thought this was going to be another thread about married life...
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • uncledickuncledick Frets: 406
    As I understand it a compressor will actively boost the quiet bits whilst sag will only ever limit the loud bits.  I'd be inclined to use a compressor for rhythm work where it can give a more solid backing to the vocals whereas sag  tends to come in when you're in full guitar hero mode and it can smooth the spikes from a loud solo. Ymmv etc.
  • VoxmanVoxman Frets: 4723
    I always thought sag was where the tone was spongier and less tight or defined.
  • CirrusCirrus Frets: 8491
    They both have the effect of reducing dynamic range, and they both vary their effect based on the signal you're pushing through the circuit.
    It's just that sag is a byproduct of having a limited amount of available power for each amplifier stage as all the stages try to pull juice from the same source, and unless you're designing the amp yourself is uncontrollable - it just is part of what the amp does. And it can have side effects such as inter-modulation between gain stages, and with the wall voltage, that introduce different harmonics
    Compression is designed to give a controllable reduction in dynamic range, there are different kinds of circuits that do the job in different ways and with different effects on the audio, but you get various controls to influence how it does it.
  • matt1973matt1973 Frets: 386
    edited January 2019
    @voxman whilst googling I found nice description of that touches on your point from a software modelling perspective:
    "Sag
    Controls power amp sag or compression 0% tight, 50% normal, 100% more touch for dynamic sustain.
     Lower Sag values offer a "tighter" responsiveness for metal and djent playing; higher values provide more touch dynamics & sustain for blues and classic rock riffs. High Bias (closer to class A) reduces the effect of the Sag control. Sag doesn’t exist in class A amplifiers since the average plate current doesn’t change.
     Sag is caused by the amplifiers power supply being unable to meet the demand when the map is pushed hard with high Master. When the power sags, the amp output drops and then recovers, creating a unique compression effect with some additional, but temporary distortion when you pick hard. Unlike compressors before the amp, sag compression occurs even when the amp is already very distorted.
     Large sag gives more compression, better sustain, and can accentuate pick attack. But the amp will appear somewhat less responsive especially at the low end and can get muddy."
    full thread here: https://line6.com/support/topic/19115-helix-amp-parameters/
  • ecc83ecc83 Frets: 1631
    Compression can be had from the pre amp section at any loudness (assuming a master VC amp) whereas "sag" is only possible as the amp pulls close to full power from the PSU.
    Probably THE best treatise on pre amps is by Merlin Blencowe and I hope he gets onto guitar amp powers stages soon cos I don't have all THAT long!
    Dave.
  • JezWyndJezWynd Frets: 6059
    The compressor pedal that best mimics sag imo, is the VFE White Horse. It gives a kind of bloom effect that I associate with sag, with a touch of gritty distortion. A remarkable pedal that is sadly no longer in production.
  • ESBlondeESBlonde Frets: 3586
    Some of That   /|\
    I can't speak for the VFH but there is something of a bloom and decay with amp sag, whereas compression (depending on the threshold, knee and ratio) tends to have make up volume later in the decay cycle and hold a fixed output level. It's also easier to invoke natural sag in your playing for expression while compression feels more 'fixed'.
