Squier JV strange switch issue
Hello guys.
I have JV '57 Strat. Built date is 01/07/83.
I need someone to explain to me this:
First of all, keep in mind, this is 100% original so everything as it came from the factory 36 years ago.
The 5-way switch is odd, but I know some JV's came with it.
It works in the reversed way - if I need neck pickup I have to push it down (originally bridge pickup way). Same with bridge pickup etc.
Even stranger with middle pickup. At first, I thought it's not working at all but recently noticed that it has very very low output. I need to turn the volume all the way on my 60w amp to hear a bit of sound.
Is it something wrong with original wiring or just faulty switch?
http://https//photos.app.goo.gl/3CJXmLNUZa6kCjcU6
  • ICBMICBM Frets: 71960
    edited January 2019
    It's not the original switch, and it's junk. And wired wrong.
    Replace it with a CRL 5-way - or if you can find one, an original Japanese-made DM-50, although they're not as good quality - and it will be fine.
    It's also possible that the middle pickup is dead, but I would suspect the switch first.
    Gonna need to change the switch for sure.
    Regarding my research, this is an originally installed switch. at some period Japanese there short on DM-50 so they started to use this crap. I saw a couple of JV's with it.
    But if it's wired wrong might be not original. I don't know... person I was buying it is the first owner and I know him well, he wouldn't lie to me  :#
  • gringopiggringopig Frets: 2648
    edited July 2020
  • gringopig said:
    I have a JV Stratocaster and they came with 3 way switches. No JVs from that era came with 5 way switches as far as I understand.
    I bought my JV 57 Strat in autumn 1986. I think it might have been a 1985 build, ex-demo stock and they'd knocked it down to shift it. It has a 5-way switch.
    But he may have a poor memory. If he's had it from new he can't be much less than 50...
    That applies to me too, but I'm certain no early Squier ever came stock with this switch, it's a later design.
  • FelineGuitarsFelineGuitars Frets: 11497
    100% try a new switch . I would use a CRL myself
    Test the middle pickup then and see if any out put or even test it's DC resistance before wiring back in .
    Sometimes a dead pickup position will sound  at high volume but it is usually just a little bleed through from one of the other pickups.
    edited July 2020
  • FunkfingersFunkfingers Frets: 14324
    One of my school/college contemporaries owned a 1983/84 model '57 style JV Squier Stratocaster. (Large Squier logo above small Fender logo.) Three-way Japanese selector switch.
    My own JV Squier Stratocaster had been repeatedly brutalised before I acquired it. None of the original electronic parts was present.
    I have a new old stock DM-50 stashed away somewhere in a re-sealable bag. Never seen solder.
    I concur with ICBM that the DM-50 is inferior to a sprung CRL switch.
    Mankonis said:
    middle pickup ... has very very low output. I need to turn the volume all the way on my 60w amp to hear a bit of sound. Is it something wrong with original wiring or just faulty switch?
    It would only take a weak connection to ground to render a functioning pickup almost silent.
    Another possibility is physical damage within the selector switch. If the PCB half of the switch deviates from its intended position, contact with wipers is reduced.
    Be seeing you.
  • rossirossi Frets: 1699
    My early one had a 3 way from new .See www.21frets.com
  • Okay, so this switch is not original? What about the other parts? Rest looks original for me.
    I will change to CRL switch and then let's see what happens.  =)
  • But as I said before, there's still possible that this is an original switch. It was added just because of the shortage of the parts during the time. Just a couple of minutes before one guy from the USA said that his JV had the same switch.
    I really don't think so. It's just not that old a switch type.
    The rest of it looks original.
    Parts get replaced, and should be, when they fail - in the past, no-one cared about "originality", especially not on what was a cheap modern guitar.
    I also remember the JVs coming with 3-way switches, and it's very likely that a lot of people changed them simply to get the in-between sounds more easily. This was the era when it wasn't considered sacrelige to modify 60s Fenders, let alone Japanese ones.
    Here is an interesting link to the discussion
    http://www.strat-talk.com/threads/squier-57-jv-strat-domestic-or-export.437536/page-2
    The Strat Talk thread is most informative.
    For instance, the photographs in posts 22 and 23 illustrate how a VLX53 selector switch should be wired. This is because the order in which its terminals are labelled is not the same as a YM-50 or the typical SE Asian eight-contacts-in-a-line switch available today.
    I suggest that somebody connected up the VLX53 selector switch whilst following a schematic diagram for a YM-50 or an American switch.
    The reversal error can be corrected by swapping the hot conductors from the neck and bridge position pickups. The wire connecting the lower tone pot to the selector switch also needs to be shifted to the unused terminal on the second pole.
    On a slight tangent, I cannot help noticing that the pickup output cables on the Strat Talk thread Stratocaster are plastic insulated whereas the OP's guitar appears to have pseudo push-back "cotton effect" insulation. (JV series Squier '52 Telecasters had something similar.)
    Be seeing you.
  • The Strat Talk thread is most informative.
    Thank you very much.
    You have amazing knowledge and helped me a lot to understand what's going on here.
    It's all clear now.
    So you think this is the reason why my middle pickup barely working?
    Cheers
    Not really. I'm just soooooooooo old that I was there when the ("non-domestic") Squier JV guitars and basses first arrived in the UK.
    I can offer no definitive answer to that question without being in the same room as your guitar. There are several possible explanations for the lack of signal. They all need checking out.
    Begin with FelineGuitars' suggestion to take D.C. resistance meter readings from your middle pickup. A reading anywhere between 5 and 7 kOhms would indicate that the pickup is healthy and, hence, the signal is going A.W.O.L. elsewhere in the circuit.
    My own preference for lever selector switches is the sprung CRL type. If you want smart Alec wiring, a twenty-four contact Superswitch is the way to go.
    Be seeing you.
    Hmmmm... not sure. Until this I’ve never seen any evidence of those switches in any guitar made earlier than 1986, but if there’s more than one with the same type it may be possible. Soldering is not definite evidence, many techs can do it well enough that you wouldn’t be able to tell.
    The switch in your guitar is wired wrongly, so at the very least it has been tampered with - if the owner doesn’t remember that I would have to call into question whether he would remember it being replaced too.
    Replacing 3-way switches with 5-ways was *extremely* common in the 1980s, not least because that Strat in-between sound was probably the most popular single guitar sound. A JV Squier was simply a cheap modern guitar of no collector interest or value - I modded quite a few without a second thought as to whether anyone would care thirty years later.
    Probably you are right. It's hard to remember what happened more than 30 years ago.
    He said, he played it for a couple of years with his punk band, then bought a better guitar.
     Since then this guitar was sitting in the cheap(ish) original hard case somewhere in the attic.
  • Btw, I couldn't convince him that this guitar is worth something now. For him, it's just not a good guitar. He gave it to me for ridiculously small amount of money.  :)
