Also chips are "Plant-based" no matter how you cook them.
I have been known to thoroughly wash amps that have had accidents involving drinks getting inside, or pedals with battery leaks. Use plenty of clean hot water and then leave it somewhere warm and dry for a week, and no problem.
In fact, *pure* water is not a hazard even if power is applied - it's not electrically conductive - the problem is the dissolved salts and sugars in tap water and drinks which make it so.
