Collision rock band
what is your current solid state amp and do you like it? Are you playing low volume at home or gigging? And why do you want to go valve?
You can do a *lot* better with either analogue solid-state or digital. Don’t write off non-valve amps just because you have a very cheap solid-state practice amp .
ICBM is dead on (as per usual ) about better solid state amps. As an example, the jazz chorus is one of the best amps I’ve used
