A slightly different angle on Digital Versus Tubes
  • TTBZ said:
    I think something like the Suhr PT15 is the way forwards, or indeed the Reactive Load IR/Ox Box/Waza Expander to "digitally model the back end" as they say. I love my valve amp and real pedals, but want digital flexibility and most importantly the ability to run it silently/through headphones.
    For live use I found this to be the worst of all worlds.
    Get an amp and stick a mic on it or get a modeller and stick it into the pa or a cab.
    Amps into loads with impulses and other bits is too complicated, requires too many boxes, too much time to set up and just ends up wasting your time debugging problems. Generally it doesn't sound better either, or at least didn't in my case.
    It's so much easier to do things like switch your amp on unloaded and blow it up as well.
    Yes yes yes, a thousand times yes!
    Another massive problem is the guitarists' obsession with making their gig-volume live solution be the same thing they use at home.
    Even with a modeller, that ain't gonna happen - at least, it's not going to sound remotely the same. So why even bother trying?
    <space for hire>
  • TTBZTTBZ Frets: 2897
    Yeah, I'm thinking more for home use. At a gig I'd just use the amp as normal. An all in one digital solution is obviously the easier solution for at home, I'm just thinking about what would be the most enjoyable solution for me.
  • You're confused because you seem to be trying to make it "this thing" or "that thing". Digital modelling can be used in any number of ways.
    The fact is that while folk try to put all modellers into a single basket with a single "purpose", they actually have many different use cases....whereas valve amps have only one (or maybe two at a push if you run them into a reactive load).
    Ultimately, they're just a hell of a lot more useful to me than any amp (or collection of amps) has ever been.
    Yeah, that is true. And my needs are very simple and I don't like too many options so I don't feel the benefit of the flexibility of most modellers.
    I posted the below video on another thread here but it highlights the point...for me, the best sounding ones are the ones that sound most like a guitar cab. Are the other ones trying to sound more like a guitar cab too? Coz they really don't. I mean, presumably when sound engineers are micing up your cab and mixing the FoH sound they are trying to deliver the sound of your guitar cab to the audience. So, in the same way, should we not be expecting the sounds out of these FRFR solutions to be 'as good as' your backline?
    I suppose once we do get that, everyone will switch to modelling/FRFR. :)
  • From looking at local band with young players here in Spain I seem to see loads of pedals into the PA or powered cab with IR
    so all the drive is coming from amp in a box type of pedals and the effects on top
  • Maynehead said:
    Maynehead said:
    Maynehead said:
    I still think "Modellers" should stop trying to model valve amps, and become Digital Amps in their own right. Only when that happens will there be real competition against the valve amps, otherwise valve amps will always be the holy grail.
    I've honestly never really cared whether a model sounds like the original amp or not...authenticity is irrelevant to me, I just use the model names as a clue to the general flavour of the block and tweak from there. If I can't get it to work, I just move on to the next one that sounds vaguely appropriate for what I'm aiming at.
    I guess the pertinent question here is: If you disregard practicality/cost/feasibility etc., from a pure tone point of view, would you prefer a modelling amp with 10 amp models, or having the 10 actual amps that are being modelled at your disposal?
    I'd rather have 10 useful amp models than the same 10 amps.
    In fact, I'd rather have three useful amp models and a couple of useful alternatives for each major effect type than 20 useful glass bottle amps.
    Practicality wins, for me. For live stuff, that means a good modeller, a tiny-but-mighty power amp and a lightweight cab. For recording...it means having them all at my fingertips whenever the urge takes me.
    I've already proven to myself that no audience member can tell that it's not a valve amp when I'm running through a real cab, and that with a great engineer mixing it, using a modeller like the Helix doesn't detract from the music.
    I'm keeping the JCA50H for sentimental reasons, but from this point forward...I'm all about the modelling.
    Maybe my question was slightly confusing.
    Basically what I’m asking is, is it the actual tone of the amps that draws people towards modellers, or is it all the other conveniences that they offer?
    If you were a millionaire rockstar recording an album at the studio, would you still use a Helix?
    Do you know how many albums have original pods on them?
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    I think we’re a bit spoilt in the UK for high end guitar and amp gear. Some of the stuff we have just lying around the house, people in other countries can only dream of, even professional bands may not be able to afford them.
    I might be wrong, and they might be just using pedals for convenience, but I bet if you offered to swap their pedals for a Mesa Mark V 25 and a 1x12 cab they’d bite your hands off...
    I don’t know of a single one...
  • octatonicoctatonic Frets: 33793
    There are loads, especially once the second iteration of the Pod was released.
    And through the 90’s truckloads of albums were done with the Line 6 Amp Farm ProTools plug-in.
  • robertyroberty Frets: 10893
    A good friend of mine recorded an album with Salaam Remi (Lauren Hill, Amy Winehouse) at his studio in Miami and all the guitars were through a Pod. This is going back 10 years maybe
  • Sorry to the original question
    I think you are right in one way stop modelling Fender marshall boogie etc.
    But then you have one big problem Guitarists.
    in a world of Strats Les Paul and Tele derivatives being probably 80% of the market who will want to play something original. Unless you spend a fortune trying to get a group of players to endorse it. Have a successful album or a tone that ignites a whole style of music.
    I think a number of software plugin companies have tried to model a few of there own things suited to a style of music but not slavishly one thing. Studio Devil back in the early days when I used it was really just some sort of good sounding hot Rod marshall without slavishly trying to model one thing. Same with toneforge menace as an extreme metal amp but most have expanded out these days to become more of what people know and expect Fender Boogie Marshall etc.
    So it’s not can it be done but do people actually want or use it.
  • dindudedindude Frets: 8537
    Genuine question - can anyone point towards a truly stunning guitar tone that was done with a modeller, recorded or live. All the talk is of convenience and “no one can tell the difference” but wondered if anyone was pushing the boundaries with them to create great sounds in their own right.
    Through my own musical taste I can only think of what Adrian Belew was doing with Roland rack gear direct to PA in the early 90’s - love the tone below, so juicy and absolutely not trying to be an AC30 or a Dual Rec.
    https://youtu.be/5dtPi8O8bN8
  • ICBMICBM Frets: 72313
    edited February 2019
    I've always used my gig-volume valve amps at home... I just turn them down, or in some cases use an attenuator. They sound the same - or at least close enough that it doesn't take a lot of adjustment to get there. I certainly wouldn't have any problem using the same modelling amp for both, since they're even less volume-dependent.
    Listen to any Garbage recording, studio or live - they don't use amps at all, just Pod Pros straight into the desk. You won't hear any "classic valve amp tones", but that's the whole point.
    It's really about understanding which bits are volume-dependent and which bits aren't. You obviously do, but an awful lot of people don't seem to get that the "boom" you get when you've got pretty much any well-set-up amp at gig volume simply isn't going to happen at home volumes, no matter what you use.
    <space for hire>
    I believe Evanescence's Fallen album was done with Pod Farm.
    And...an awful lot of recordings have been DI-ninja'd without the band's knowledge, or the guitarist's. Mainly because studio engineers know how precious thin-stringed princesses can be about these things ;)
    <space for hire>
  • sgosdensgosden Frets: 1994
    Depends on the venue, and time constraints. For a decent venue, when you get a sound check, then yeah chances are the FOH will move the mic placement a bit, but that tends to be to suit the sound of the room.
    majority of smaller venues or the dog&duck, when FOH have got 30 minutes to check 4 bands before doors open... they just need some sort of signal coming through their mics to put through PA.
  • I think the issue with modelling is that traditional guitar amps are in a way 'broken'. You are basically getting a signal and putting it through a series of tubes, sometimes at a high enough level to run them out of spec, and then it goes to a rubbish speaker with limited range.
    Tubes are funny as well, as they are completely analog and rely on physical processes, their operation can depend entirely on atmospheric noise and this is almost impossible to model.
    It's also difficult to model the interaction between speaker and amp without developing some sort of smart speaker that could programmatically adjust the way it operates and in this way through communication between the speaker and amp, we could get a more realistic output.
  • Yeah, that is true. And my needs are very simple and I don't like too many options so I don't feel the benefit of the flexibility of most modellers.
    None of them sound like a guitar cab, apart from the Line 6 Powercab - when it's being used properly. Why? Because microphones aren't ideal sound detection devices with entirely flat responses. They affect the tone as much as the choice of speaker does.
    No. they're trying to get a sound into the desk that's ideal for the way they want to work with it which results in the best overall sound getting into the audience's ears. Generally speaking, that's not particularly related to the sound that the guitarist wants to get from their amp/cab.
    <space for hire>
    That's very true. You might actually be able to get it closer with modelling and headphones, simply because you can get the apparent volume up to the same levels. Personally I hate playing through headphones... but modelling may have an advantage exactly because there is always a small amount of latency, which mirrors what you get when you're standing a little further from a real amp - there's a delay of about 1mS per foot purely due to the speed of sound.
    You can get closer to the apparent volume, but then you lose the environmental reflections - which are also massively important, IMO. Your brain expects them to be there, so when they're not...uncanny valley.
    <space for hire>
