Frequency dependant Distortion - is it a thing?
JezWyndJezWynd Frets: 6053
As in, play a low note and it sounds clean, play a high note and distortion is applied with a pot to determine what's clean and dirty. An expression pedal would probably do the job very well but I'm already using a Whammy to go from low to high, so two treadles simultaneously isn't going to work.
