And yes, it does have direct monitoring so the round trip for that is the usual 3 milliseconds or so of A/D-D/A conversion. So yeah, you could route a DI input back out to an amp for monitoring.
I can't remember whether the channel sends are normal or half normal, so there's an off chance you could split the signal there and not even need to bother with the direct monitoring, though I'd need to check...
Again, though, low latency performance isn't great, compared to what I've had in the past. That doesn't bother me personally because the form factor - physical volume knob, easily reachable dim, cut, and mono buttons - are handy for mixing, and when mixing I'm using the highest buffer sizes anyway.
Bandcamp
Spotify, Apple et al
The routing is also good; you can send signals out through your 3&4 outputs for re-amping or hardware sends from your DAW, just make sure you don't put the "DAW THRU" option on anything you are monitoring with, it could take your hearing out!
