I'm doing some minor changes to my rack, and swapping out a pedal, the rack is really well cabled, professional job, pancake jacks just perfect, until I swap this pedal out, which has the input/output right next to each other so the pancakes won't allow both to plug in at the same time. I don't want to swap this cable out, nor do I want to take the jack off as chances are %50 that I'll either swap this pedal back or swap it to something different after some real world use.
Is it possible, is there a device or cable that can be made that will allow me to present one of the jacks as a standard "long" jack rather than pancake to test this pedal out ? sort like a headphone extension cable ?
You won't be able to get one made for any less than that.
not so much worried about the cost, it's something that would be handy to have around anyway, more worried about the quality and will it work and will it impact anything ?
This looks a great solution if you think it's something of "ok" quality
@ICBM is right about the price - Neutrik connectors alone would cost > £10.
This one is better quality: https://www.amazon.co.uk/Van-Damme-SPEAKER-Extension-Conductor/dp/B076PJQSMW
Ignore that - it's a speaker extension. But the same with signal cable would be a similar price.
R.
Eqd Speaker Cranker clone
At that price I'd probably buy two if this is something you may need again.
