swapping stuff out in my rack at the moment and I can't figure out if / how I can power a Roger Linn Adrenalinn 3 from an CAE/MXR MC403 rack mount power supply.
Found some info on the voodoo labs PP2 and using a voltage doubler, but I can't quite work out if it's possible (I'm sure it is) with what cable/outlets ?
Anyone work this out, I can see a high draw of 500 mamp, but it's 9v dc - so a standard 9v power out on this looks like it should work, but doesn't.
What am I missing ?
so that was my initial thought until I read about the voodoo lab pp2 which has the same spec (from what I read) as the CAE, but it just needs as you say, a custom cable
interesting.
appreciate the thoughts
