I have a cheap but rather nice five string Vintage AV4+1 Bass Guitar (One of the Trevor Wilkinson ones). It t incorporates a precision bass neck with a jazz bass body. My tech also installed a bone nut.
I wanted hum-cancelling pickups and we therefore installed a pair of Bartolini 57J1 L/S split coil pickups - these have side-by-side dual inline hum-cancelling coils (but look like Jazz Bass pickups - without the 'offset' of the Precision Bass pickup).
I’ve always liked the sound of the precision bass and I was particularly impressed by the sound that Wayne Banks got at the Classic Rock Show gig in Norwich. Pretty much the best bass sound I've heard at any gig - period.
Given the architecture of my pickups, I find myself wondering whether the neck pick up will give me a close enough approximation of a Precision Bass...?
Part of the classic P Bass pickup sound comes from the dimensions of its coils. Another important feature is rod magnet polepieces.
In order to extract similar tones from your Barts, it will be necessary to employ active equalisation to further manipulate the low and midrange frequency bands. Even after doing this, the bar polepieces of the Barts will not cop the transient attack of a vintage Fender pickup.
In my opinion, you should enjoy the Barts for what they do.
On reflection, your best short cut to vintage bass guitar tones from your instrument could well be flat wound strings.
The pickup positions are also quite a bit different - the P pickup is closer to the bridge, more or less in between where the Jazz pickups are - and that makes a surprisingly large difference.
A possible option is to connect the two Jazz pickups in series instead of parallel - that will give more of the fatter, punchier tone of the P.
But after looking at the bass model itself and seeing that one sold used on basschat for only £125 - the cost of a good pickup and the work would be more expensive than the bass.
Even then the P pickup wouldn't be in quite the right position. I've had a few basses where the P is either a bit forward or back - often by only half the width of the pickup and it does make a difference.
But if you only use the neck pickup and then EQ it with a mid boost and cut the bass a surprising amount and cut the treble a bit then you will get as close as you can with what you have.
Old skool P pickups are surprisingly low on real bass freqs - it's all about the mids instead. No doubt that was the aim as a Double Bass doesn't really have lots of bass freq either.
That's why people who put in SD Quarter Pounders etc as an "improvement" then moan their beloved bass doesn't sound like a precision anymore. Of course it won't! They just picked a new pickup with boosted bass and cut mids - the opposite to a vintage P pickup!
There is also the matter of early Fifties electric stringed instrument amplification not being able to deliver the really low end.
Nicer neck shape than a Fender too - little narrower at the nut and is far more comfy.
Controlled bottom, tons of clank - but is very reactive to the tone control so it backs off the clank beautifully.
It's now my favourite P pickup.
To be honest I'm mostly using my Dingwall Combustion. I did try a P-Tone and I didn't love it, a little too bright with steels. I think the stock pickup wired series sounds closer to what I'd want out of a P. I need to get some series/parallel switches fitted at some point.
Well, what I'd really love is a Super P. I hope they'll do an import version one day.
Perhaps a 4 string will be fine - just tune it down a tone to get that low 'D'
