Line 6 Helix
  • Thanks for the invite, Drew! :D
    Chief Product Design Architect, Yamaha Guitar Group | Line 6 | Ampeg
  • HeartfeltdawnHeartfeltdawn Frets: 22096
    @Digital_Igloo
    Does the effects loop sum to mono at the Sends?
  • thumpingrugthumpingrug Frets: 2890
    Dude only said he'd been working on it for 4 years - he didn't say he'd been working on it for 4 years while working for Line6 ;)
    The first conversations on what would become Helix took place in October of 2008. My first Illustrator mockup of what would become Helix was in November of 2011, and back then it had a touchscreen. In retrospect, that was a dumb idea, as touch footswitches are so much faster and easier.
    Great to see you here @Digital_Igloo    The Helix looks fantastic.  Welcome to the forum.
  • Heartfeltdawn;669287" said:
    @Digital_Igloo
    The Send/Return category has both mono and stereo subcategories, so yes.
    Pulled these names from the Sweetwater video:
    Dynamics:
    Deluxe Comp
    Red Squeeze
    LA Studio Comp
    Noise Gate
    Hard Gate
    EQ:
    Simple EQ
    Low and High Cut
    Parametric
    10 Band Graphic
    Modulation:
    Optical Tremolo
    60's Bias Tremolo
    Script Mod Phase
    Ubiquitous Vibe
    Gray Flanger
    Harmonic Flanger
    Courtesan Flanger
    Chorus
    (more...)
    Delay:
    Simple Delay
    Mod/Chorus Echo
    Sweep Echo
    Ducked Delay
    Transistor Tape
    Bucket Brigade
    Adriatic Delay
    Elephant Man
    I do wonder whether they're final options or if the Sweetwater guys were running an older beta firmware, because I'm missing a Reverse Delay - and in the video the delay category didn't have a little down arrow at the bottom of the list, indicating more available options - so I hope that isn't the lot for delay! It must not be really... coz they had the Harmony Delay in all the promo stuff, and it wasn't in the list in the Sweetwater video.
    Anyone wanna take a guess at what an Adriatic Delay could be, or the Elephant Man?? My guess is the Adriatic Delay is some kind of huge washy ambient delay and that the Elephant Man is apeing a real world pedal of some kind, possibly a Memory Man - elephant's never forget and all that....
  • Glad the sweep echo is in but I want the low res delay and a reverse delay!
    That said, I suspect adding more algos is just a case of plugging into a computer and updating it...
    edited June 2015
    I also noticed that in the reverbs, the 63 Spring had a low and high cut, which you did not get on the M-series units... and another page of parameters that we didn't get to see too. So even though the reverbs are ported over to the new HX modelling from the M-series era, we could still be looking at a whole host of additional parameters there for the tweaking.
    I wanna see the parameter list for the Hall algorithm for sure!!
    Also since you've got two signal paths to futz with.... I imagine you can send from one path to the other using one of the splitters, add a chorus, then a reverb, and then merge it back into your main chain at say 25% mix.... and you've got an instant Eventide "Blackhole" style algorithm!
    Lot of creative uses by having a separate chain that you can tap into.
  • guitarfishbayguitarfishbay Frets: 7953
    edited June 2015
    @Digital_Igloo how does this address options for modelling interaction with speaker cab impedance and resonances? On the Axe FX to get a good result at higher volumes through a solid state power amp and traditional speaker cab you need to set the low frequency resonance parameter to match your physical cabinet otherwise the low end punch is 'wrong' at high volumes, I find it noticeable with closed back cabs. This was one of the major differences between the HD500x I had and the Axe FX 2 I now have - at higher volumes through Matrix GT1000 and Mesa Recto 2x12 I could get better response from the Axe FX with less tweaking. The POD was serviceable and had enough features, but IMO the Axe FX sounds and feels better when used that way.
  • KrisGeeKrisGee Frets: 1264
    Hard to comment on the sounds as all we've heard so far is demo videos and they can sound whatever they make them sound.
    All I can say now it just seems to small to me.
    I really wish the spacing between buttons was bigger. Especially now when you can also edit patches hands free.
    I digged my hd500x for a while but couldn't live any longer with the size of it, too many times pressed something else that I wanted.
    Center-point spacing between Helix's footswitches is identical to that of M13.
    A bit more copy-pasta:
    Okay—here we go, one-point-oh:
    Input Blocks:
    None, Multi (Guitar, Aux, Variax), Guitar, Aux, Variax, Variax Magnetics, Mic, Return 1, Return 2, Return 3, Return 4, Return 1/2, Return 3/4, S/PDIF, USB 3/4, USB 5/6, USB 7/8
    Output Blocks:
    Multi (1/4", XLR, Digital, USB 1/2), Path 2A, Path 2B, Path 2A+B, 1/4", XLR, Send 1/2, Send 3/4, Digital (S/PDIF, AES/EBU, or L6 LINK), USB 1/2, USB 3/4, USB 5/6
    Distortion Models:
    Minotaur, Compulsive Drive, Valve Driver, Top Secret OD, Scream 808, Hedgehog D9, Vermin Dist, Arbitrator Fuzz, Triangle Fuzz, Industrial Fuzz, Tycoctavia Fuzz, Megaphone
    Dynamics Models:
    Deluxe Comp, Red Squeeze, LA Studio Comp, Noise Gate, Hard Gate
    EQ Models:
    Simple EQ, Low Cut/High Cut, Parametric, 10-Band Graphic
    Modulation Models:
    Optical Trem, 60s Bias Trem, Script Mod Phase, Ubiquitous Vibe, Gray Flanger, Harmonic Flanger, Courtesan Flange, Chorus, 70s Chorus, Trinity Chorus, Bubble Vibrato, Vibe Rotary, 122 Rotary, 145 Rotary, AM Ring Mod, Pitch Ring Mod
    Delay Models:
    Simple Delay, Mod Chorus Echo, Multitap 4, Multitap 6, Ping Pong, Sweep Echo, Ducked Delay, Transistor Tape, Harmony Delay, Bucket Brigade, Adriatic Delay, Elephant Man
    Reverb Models:
    Plate, Room, Chamber, Hall, Echo, Tile, Cave, Ducking, Octo, 63 Spring, Spring, Particle Verb
    Pitch/Synth Models:
    Pitch Wham, Twin Harmony, 3 Osc Synth
    Filter Models:
    Mutant Filter
    Mystery Filter [Hi, Stilwel—we miss you, brother!]
    Wah Models:
    UK Wah 846, Teardrop 310, Fassel, Weeper, Chrome, Chrome Custom, Throaty, Vetta Wah, Colorful, Conductor
    Volume/Pan Models:
    Volume Pedal, Gain, Pan
    Send/Return:
    Send 1, Send 2, Send 3, Send 4, Send 1/2, Send 3/4, Return 1, Return 2, Return 3, Return 4, Return 1/2, Return 3/4, FX Loop 1, FX Loop 2, FX Loop 3, FX Loop 4, FX Loop 1/2, FX Loop 3/4
    Looper:
    Mono, Stereo
    Split:
    Y, A/B, Crossover
    Merge:
    Mixer
  • hugbothugbot Frets: 1528
    couple of things missing from that effects list I want.
    Namely the frequency shifter and lo fi delay models from the m series. A POG, reverse reverb and delay and some bass wahs. Hopefully the included filters can sweep low enough for bass as I had that issue with the M series.
  • spacecadetspacecadet Frets: 671
    Worth remembering Line 6 always did the model packs. I don't see why this should be any different. It may be that (like the H9) you will be able to buy bolt on amp/ fx packages. Or they could just do regular updates and add more as they get round to modelling more.
  • longilongi Frets: 95
    edited June 2015
    Welcome to the forum Mr Igloo!
    Will the harmonizer have the ability to have custom intervals programmed? Or will it just be standard modal intervals? ie will the harmoizer also have Phrygian/Lydian Dominant intervals added?
    Having seen the Helix the AX8 looks quite last generation by comparison.
    Yamaha/L6 have huge economies of scale behind them compared to Fractal. If it's going to be the heart of a new generation of products for the next ten years they could well have designed their own custom silicon which is going to give them a significant advantage.
    If I worked for Fractal I'd be worried. With Yamaha's buying power Line 6 will be able to buy processors cheaper and will be able to take advantage of Yamaha technology and R&D.
    It all looks very interesting ...
    So if I have a stereo delay prior to the Effect Sends and Returns and wish to use a stereo Send, that delay gets summed to mono?
    If so, that's the same flaw the M13 and M9 had. That it's replicated on a device as expensive as the Helix is pretty bizarre.
  • stonevibestonevibe Frets: 7083
    Wait till V2 hits the streets.
    With Yamaha's clout behind them, this line will evolve fairly fast. Yamaha tend to have a model out for a few years max and then bring out a suped up version fairly fast.
