FS/FT Epiphone So Cal 50 head £100!-SOLD
grungebobgrungebob Frets: 3477
edited February 2014 in Amps £
For sale or trade is my Epiphone 50 watt head,
Features
Designed and engineered in the USA by Gibson
50W or 25W Class AB switchable
All-tube circuitry
2 channels
Solid state rectifier
Presence control
Contour knob and gain control for channel 2
Tube-powered reverb
Independent/interactive EQ switch
Standby switch
Shared 3-band EQ
Master volume
Dual 4 ohm, dual 8 ohm, and 16 ohm speaker outs
12AX7 preamp tubes with DC powered filaments
EL34 power tubes
Footswitch jack (switch not included)
High-tension fuse
16-gauge bent and spot-welded chassis
11-ply plywood cab construction
26"W x 10-3/4"D x 10-3/4"H
42 lbs.
Cab not for sale
http://i1034.photobucket.com/albums/a428/grungebob/Mobile Uploads/CAM00006_zpswjqnz89u.jpg
No longer needed as its more blused base than my needs, reverb is intermitent and ive a homemade channel changer so looking for a bargaintastic £100 collected from grimsby area could  consider trades too for interestig pedals or pickups type stuff
  • grungebobgrungebob Frets: 3477
    Bump
  • DeijavooDeijavoo Frets: 3307
    When you say intermittent, can it just be switched off?
    Oh yeah. It can be controlled via the pot but most of the time it doesnt come on, spring seems fine maybe the valve but thats beyond my technical abilities
  • Sorry to hijack your thread but how do you find the SE amp?
    Thats ok, love it! The clean channel is really great with bags of gain on tap,perhaps not enough headroom to gig so the se 30 might be best there. The drive channel is an awkward beast,with the wrong pickups it can be a tad fizzy but use the right ones and its Soldano slo like heaven
  • I thought these amps were designed by Mike Soldano? Supposedly very "Soldano" sounding?
    No idea, but it sounds like one to me \m/
  • SimpleSimonSimpleSimon Frets: 1025
    thanks for the info, been eyeing up the SE50
    No one want a versatile valve amp for not much coin? Would even be interested in trades for pickups and pedals.
  • nickpnickp Frets: 183
    feck it.  can you stop stalking me with this head!
    @grungbob - if you can box it up to courier then i'll have it and get a joyo pedal to send it to the stratosphere
    let me know your paypal address before I have a coffee and change my mind again :)
    interparcel will courier for about £10.  i'tll be fine I've sent engl amps around the world with them.  so if you want to add it to the paypal amount then that will be fine by me.
