Looking for a screw for the pickup rings on a Gibson Les Paul...
NeilNeil Frets: 3847
edited May 2017 in Guitar
As above, one of the screws on my pickup surrounds is very rusty and graunched up (bridge pickup) and I want to change it out.
Are they all the same length etc?
Where can I get replacements?
TIA.
photo DSCN2564jpg
  • GagarynGagaryn Frets: 1553
    TIA.
    photo DSCN2564jpg
    Neck and bridge are different lengths, at least they are on my ES...
  • AlegreeAlegree Frets: 670
    I stock both humbucker screws & pickup ring screws. Unsure which you're after here.
  • NeilNeil Frets: 3847
    Pickup up ring screw for bridge humbucker.
    If you mean the screw that secures the pickup to the ring then ignore my earlier answer. This screw is a bolt if you ask me! :-) Folk call them machine screws sometimes though. And they are the same size, neck and bridge.
    edited May 2017
    No, it is the woodscrew that attaches the plastic pickup ring to the guitar body.
    I can see how the bridge and neck versions would be different lengths.
    I guess I could look on ebay but my gut feeling is that most of the stuff on there would be for oriental copies which use metric as opposed to Gibsons which use imperial.
    What? machine screws are entirely different things. These are wood screws.
    Anyway, here's my listing for them if you choose to buy some https://shop.alegree.co.uk/collections/pickup-ring-screws/products/pickup-ring-screws
    Cheers, I assume these are the longer screws for the bridge ring and imperial threads?
    If so I'll order some up.
    They appear to be the longer type. My supplier sells them as universal ring screws, so they ought to be long enough for all applications.
  • SteveRobinsonSteveRobinson Frets: 7343
    It's a machine screw. Strictly speaking a bolt has an unthreaded length below the head.
    pah! :-)
    edited May 2017
    The front and back pickup rings have different length screws and there is a difference between imperial and metric threads so I think I'll leave it thanks.
    you need 1/2 inch for the neck and 3/4 inch for the bridge. Think they are no.2 but you should check by measuring existing ones. Pay attention to the head shape - my guitar has flat top screws but is from the dark days of Norlin, noticed those linked above had a slight dome.
    Thanks for that :) Mine are the slightly domed versions (2004)
    I'll have to whip it out.
  • streethawkstreethawk Frets: 1657
    edited May 2017
    I sell them in sets of 8 for £4 delivered.
    http://www.amberguitar.com/home/181-humbucker-pickup-surround-screws.html
    Aged is 4.50.
    http://www.amberguitar.com/home/180-aged-humbucker-pickup-surround-screws.html
    Appears to be 16 screws there.... remind me to fire David Bailey.
  • ESBlondeESBlonde Frets: 3646
    edited May 2017
    I don't know what the P&P cost is on top but Fake 58 sell them if @streethawk hasn't got what you desire. Obviously forum members are better suppliers ;-)
    http://www.fake58.co.uk/G Hardware.htm
    edit:
    Having checked it's £4.50 P&P atop the parts on fake58 site so definately go with amberguitar.
    Aged is 4.50.
    Cheers.
    Order placed for a set. :)
    Mine are #2 3/4 inch. US bridge size.
