The price is £120 *each* for my Radial Headswitchers. Power supply included.
These allow you to connect two amps to one speaker cabinet. The amp that is not connected is protected from the dummy load inside the unit. With one press of the footswitch you could change from a Fender Bassman for clean to a Mega high gain amp....or whatever you want.
You can also connect a standard latching footswitch so that you can "remote control" the switching leaving the Headbone with the amp and just running a mono cable by your feet for the switching.
There are two versions.
1. VT - Valve - Tube....here both amp heads are valve / tube.
Two of the pretty jack covers are missing..it makes no funtional difference.
2. TS - Tube - Solid State... you guessed it
They are currently showing as £278 each at Andertons or £261 via Thomann.
Cheers,
Andy
R.
Eqd Speaker Cranker clone
I presume from your comment it's not working?
R.
R.
