So, I'm looking for a little workshop amp that can be kept in a "shed", fairly cheap obviously.
It needs two functions, an inbuilt tuner, and output. The quality of the tuner is more important, all I need in terms of output is for checking pickups after wiring etc, so the quality of the tones isn't that important.
Really small footprint would be ideal, like as small as possible.
Ideally if it exists I'd want something like a Boss TU with an inbuilt speaker and amp sim. Like I say, the quality of the tuner is more important, so I don't really want the tuner to be a basic red light/green light type thing or a yes/no, a dial or something that tells you how far you are out is preferred.
Thanks.
I know I could just get a TU and a Blackstar ID battery powered thing - but if I can help it, I'd rather just get the two in one, so I don't have to change cables about etc - I'd just leave a cable plugged into it.
Feedback
But a Sonic Research tuner instead.
Feedback
I guess I could lay it on it's front...
It's actually getting quite hard to find any small amp with the controls on the front these days now the fashion has gone back to top-mounting.
Those Vox amplug things are tiny, so it's clearly possible to make something the size of a large pedal that does everything I'm asking for.
Vypyr and Spider both look a bit bigger than I was looking for - space is at a premium, and being able to easily move it around is ideal.
https://www.thomann.de/pics/bdb/107460/6237890_800.jpg
Is there something equally small that does have a speaker? Or is something the size of the Micro Crush the best I'm going to get with a speaker?
