For what it's worth, reheating all the solder joints without identifying where the problem is is *not* a good idea, you can easily make things worse. Melting the solder without really getting it hot enough or adding fresh fluxed solder can cause cold joints.
If the buzz stops when you touch the shielding, it should also do so when you touch the back of the volume pot.
There is a black wire which runs from there to the trem claw. If touching the trem claw doesn't stop the buzzing, either there is a broken or cold joint at one end of that wire, or the wire is broken in the middle - unlikely but not totally impossible.
If touching the trem claw *does* stop it, then the springs are somehow not making an electrical contact to the bridge - which I would find difficult to believe, but isn't totally impossible I suppose…
Ha
Dimmer lighting, computer power supply, mobile phone charger, drummer, that sort of thing...
Are both UK voltage models, or US imports with stepdown transformer?
Guitar buzzes through two amps when other guitars don't indicates it's the guitar. Guitar buzzes through one amp but not another when both are plugged into the same socket indicates it's the amp...
If it isn't a massive faff, take the other amp to the rehearsal room next time and confirm that buzzes too. (And the Mesa still doesn't.)
