My HT20 made a "pop" through the speaker while sat in standby warming up, then wouldn't work at all. Nothing through the speaker out or emulated out. Power light and channel select light still working. All valves glowing normally.
The HT fuse had blown. I reseated all the valves, replaced the fuse and it was OK in standby, but blew again as soon as I took it out of standby.
What's the first thing to try? Could a valve have given up and blown the HT fuse while the amp was in standby? (I thought standby turned the HT circuit off). The preamp valves are one per channel, so I could try a known good one in each position and see what happens - is that a good idea? If that fails, I've got a spare pair of power valves, but I don't want to risk damaging anything else.
Is a dodgy valve the most likely cause of this? Any known weaknesses in the HT20 that I should get looked at before I just swap valves around?
OK, thanks - sorry, perhaps I got the wrong end of the stick! I use my HT20 head for everything at the moment, including live. It's got way more gain than I ever want to use (I think you're right that they're popular with the metal fraternity - I'm running a 12AY7 in the drive channel preamp to make it a bit tamer) but I really like the sound of it. Recently we've got another guitarist in the band and sometimes the dark sound of the Blackstar struggles to cut through against his Fender amp (I'm finding myself running the treble way further up than I used to) so I'm possibly thinking about getting something else, but I still like the HT so will probably hang onto it even if I end up using something different in the band.
It seems pretty reliable - I've had it three years and apart from one suspect preamp valve I've not had a problem with it until now.
Yes it's definitely an HT-20. I didn't say it had a standby switch, but it does have a standby mode - it's got that freaky "standby controlled by the input jack" thing. Ridiculous idea, but you get used to it![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
I will set the bias as soon as I get the new valves - it hardly changed going from the original TADs to the JJs I had in there, so I'm sure they'll survive a few home practice sessions without rebiasing (the old TADs are back in there now temporarily).
I have started running an EQ in the loop of mine recently, and it does help a bit. I like the voicing of the amp and the weird standby doesn't bother me now I'm used to it - I wasn't intending to come across as negative![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
BTW, Dave, what is YCPAOTPAOTT? The only reference I can find to it is from another of your posts on this forum, and I still can't work it out from that... I suppose it stands for "how do you keep an idiot in suspense?"![;) ;)](/plugins/EmojiExtender/emoji/fb/3.gif)
