Before I go ahead and buy a Nova system can you guys help me to confirm this is possible please.
What I want to do with the Nova:
- Switch between crunch and super crunch on my Blackstar Series One 100 head via midi.
- Have the Nova in the loop for a bit of reverb and a bit of delay.
- Possibly have a clean boost setting on the nova as a lead boost through the FX loop?
Looking at the manual I am pretty sure this is possible using a couple of presets but just wanted to check as this is new to me!
Many thanks.
EDIT: Typically I have found this which seems to confirm my thoughts
http://forum.tcelectronic.com/topic/12595/channel-switching-blackstar/
My reservations are now based on people having trouble setting up levels when using it through a loop or the Nova causing tone suck but it seems the boost function on the pedal is actually a volume attenuator for the rest of the unit and setting that to 0db brings it back up to unity.
I don't suppose you know if using the EQ in an FX loop gives plenty of volume boost do you?
One thing I hate about my setup with the Nova is this tough - you need to be very careful what you set the input gain to when using it in the loop with some amps. On my Traynor I have individual preamp volumes for each channel which are set by to pretty much the same whether I play live or at home, and then I use the master volume to control the overall volume, which is after the fx loop. This works very well with the Nova because I can set the input gain so that the nova doesn't clip and then adjust the volume of the amp without worrying. On my regular gigging amp - a H&K Tubemeister 36 - each channel has a volume control, but there is no overall 'master' volume. When you crank the amp the signal that gets sent to the send jack is the signal that is increased, so I guess it is a preamp volume control. This means that the input gain setting on the Nova now is too hot causing it to clip, which means I have to adjust it when setting up for a gig. No biggy and you get to know the appropriate values but still a bit of an annoyance.
Going back to the midi - the Nova has full program change mapping which makes setting up your amp control easy - have program change 1 set to amp clean, 2 to dirty etc, and then each patch you want to use the dirty channel of the amp you just need to map it to send, for example, program change 2, which makes rig management much easier than other multis I've used.
I might just go back to a Bassman and a tubescreamer lol.
Yeah sounds like you will be fine. I've done the same many times - gone back to just using a few pedals in front of my Blackheart Little Giant, but in the end I succumb to the lust for delays and reverbs and go back to the Nova. At home I have my midi rig:
G- Lab BC1 (boost and compressor) > Tubemeister 36 > amp send > Source Audio EQ > TC Nova System > amp return, all controlled with a Behringer FCB1010 with the Uno firmware. This is pretty much the perfect as everything can be controlled by the FCB1010 and the rest forgotten, but is too much for most gigs. Which is my point really, because of the lack of 4CM with the Nova you may find yourself lusting for some stomps up front, so you end up putting the nova on your board with the stomps, then you suddenly find yourself needing 3 guitar cables going between amp and board, 1 midi cable, 2 power cables (nova kettle lead and pedal boards psu) and suddenly you have a right mess on stage!
Only issue I have so far is a bit of sound overlap / lag when switching between these 2 presets:
Preset 1 - Blackstar on clean channel with drive sound coming from NS
Preset 2 - Blackstar on crunch channel no drive coming from NS
When I do this there is about half a second of the drive effect from the NS spilling over to the crunch channel. Not a big deal live as you can't really notice it but pisses me off at home.
Delays, reverbs and the fake leslie sounds are awesome, the boost is handy and the drives really are very good indeed.
