Are my pickups too low?
ricorico Frets: 1220
I'm having a little tweak and I noticed that my pickups seem relatively low compared to some of the specs that are floating about the internet. On my tele they are as follows (measurements taken with string fretted at last fret, top of pole piece to bottom of string)
Neck: 2.75mm & 3.5mm
Bridge: 2.5mm & 2.75mm
Fender publishes around 1.6mm & 2mm on their website...
  • AlegreeAlegree Frets: 667
    Do you have an issue with their tone or output?
    It's a taste thing.
  • You could always tinker with it- any changes are easily reversed.
    It can make a surprising difference to the tone of your guitar.
  • ricorico Frets: 1220
    I have spent a good hour or so tinkering this afternoon, I prefer the tone of the bridge when it is higher however the neck is then too quiet. I prefer the tone of the neck when its lower but then the bridge isn't as good!
  • guitars4youguitars4you Frets: 14808
    it is  a matter of taste - to a degree even playing style - maybe string gauge and how heavy/light you pick
    Best bet is to play around and adjust accordingly - certainly no set measurement - If to close you can generally hear a nasty sort of clangy attack, especially when hitting Who style power chords, just as a reference - So back of accordingly until this cleans up - If to low you lose bite/power, but some might like this for a chilled voice
    Best bet is a marginal adjustment each time, then you only need to fine tune a touch to go back to as was
  • ICBMICBM Frets: 73074
    One high, one low is allowed :). This is one of the things I like about Teles - the natural difference in voicing and output of the pickups makes it possible to use the pickup selector as an overdrive switch, with the right amp settings.
    The only wrong pickup height setting is if it's so close the strings hit it when you play hard - that doesn't sound good.
    Around 2mm is the closest I'd like to go with passive pickups. If you go closer than that you'll risk the magnetic pull on the strings doing weird stuff to your tone and intonation.
    I had a strat that I just could not get the intonation right no matter what I did... turned out the bridge pickup was too close and gave the string a weird sitar like harmonic overtone that was screwing with the tuner.
  • aord43aord43 Frets: 287
    I recently looked this up - not Tele specific - and found a couple of recommendations that they should be about 3.2mm and 1.6 mm (the originals were in inches, being US) which is not too far off your original settings.  But everywhere it says there are no hard rules.
    Interesting! There was a premier guitar article specifically describle Tele pickup heights and they recommended that the bridge pickup on the treble side should be 2/64ths! That's about 0.8mm...!
    Actually that is true - although it's more normally a problem on the neck pickup.
