Hello all,
Planning or rebuilding my pedal board with either a Schmidt Array or Friedman board and want shiny new cables to go with it.
Whilst putting these cables together is allegedly straightforward, apparently there is also a learning curve and painful thumbs to go through.
So does anyone know of a service where I can buy or provide the parts and someone can put them together for me?
I would obviously specify lengths etc and guess it is anywhere from 2 to 3 hours work.
Just looking for someone who can do the job properly and charge a fair amount
Cheers
i can do it for you no problem, but it will cost money, up to you.
instructionals on you tube.
Thanks @gassage.
@custompedalboards, just pm'd you.
I am sure I could do it, it is more the time factor, I would happily pay someone to do a proper job rather than my ham fisted attempts.
Plus I have 2 kids under 5, and a wife that claims they will melt if not given my full attention whilst at home.
Honestly, its REALLY easy stuff to use .
I have 8 pedals and an 8 loop switcher and it took maybe 3 hours and most of that was measuring cable lengths and stripping the cable ends ... just take your time and give it a go.
I had the same setup for years on a pedaltrain with soldered monster cable / neutrik jacks and there is absolutely no discernable difference in sound quality between soldered and solderless either imho. Its just that with the SIS it was a shitload easier - and neater - to wire up.
I have used George L in the past with zero issues but had problems with some Lava cable stuff I briefly tried (although the PIston stuff seems ok)
He even made me a custom switcher and set it all up, just what I was looking for.
Here are some pics
[img]https://i.imgur.com/jUa2NEM.jpg[/img]
https://i.imgur.com/v6aQ5RA.jpg
https://i.imgur.com/wUN1C7B.jpg
https://i.imgur.com/JJxb6So.jpg
