Guitar through Bluetooth Speaker?
JerkMoansJerkMoans Frets: 8871
edited February 2018 in Amps
Ladies and djentlemen: greetings.
So here's a poser.  I've just scored one of the newish Fender bluetooth speaker jobbies in a lucky eBay swoop.  While I'll be using it in the main to play music from my phone, my mind then started turning to whether it could be used as an impromptu guitar speaker.  Bit of googling later and I'm none the wiser, albeit slightly baffled by talk of some arcane lore of 'latency'.
Anyone know whether there's some sort of dangly bit you can wang into the jack socket of your guitar that will let you project straight from there and into the bluetooth speaker?  It seems such an obvious thing to be able to do...
Inactivist Lefty Lawyer
  • ecc83ecc83 Frets: 1663
    Blackstar do a gismo that goes the other way, Bluetooth into an amp so I bet somebody does what you need. Will have a look.
    https://www.amazon.co.uk/Bluetooth-Transmitter-Universal-Headphones-transmitter/dp/B076LGQS2S/ref=sr_1_1?ie=UTF8&qid=1517676216&sr=8-1&keywords=audio+transmitter+Bluetooth
    I am sure that ^ could be made to work but, input Z is likely 10k and a guitar will sound ***t. You could drive it from a buffered pedal.  Not a lot of money to try?
    Dave.
  • JerkMoansJerkMoans Frets: 8871
    Yeah that's the first thing I found when I was Googling, and thought 'yippee', until I actually read the blurb and realised it was the opposite to what I'm after.
  • antifashantifash Frets: 603
    I’ve  been unable to Bluetooth using iRig and GarageBand, but I just use a 3.5mm jack to jack from my iPhone / iPad to speaker. Not Bluetooth sadly.
  • PlectrumPlectrum Frets: 494
    I believe latency over Bluetooth can be quite high. That may or may be an issue for you.
    One day I'm going to make a guitar out of butter to experience just how well it actually plays.
  • martmart Frets: 5205
    I’ve tried playing a guitar into a speaker via bluetooth and the latency made it impossible. If your speaker has an aux input then you could plug your guitar in to that input to avoid latency, but you’ll likely need to go through a different amp in order to get it to sound any good.
    In short, it’s a bit of a non-starter.
    Ah! Yes, latency. I had forgotten about that. There is more than one BTh audio protocol I shall see if I can find and more dope on the subject.
    Just remembered, whilst searching for BTh  'guitar transmitter' I came across a 2 piece jack guitar wireless T/R kit, maybe they are not BTh though?
    'Oil be beck!
    Dave.
    'Oil be beck!
    Dave.
    Yep, Bluetooth latency is around 200-250ms. Not terrible if you're listening to music, or even having a conversation with someone, but try to watch a video without OS compensation and the lag will be very noticeable. Playing guitar through it is a non-starter, as far as I know.
    <space for hire>
    This 'latency' smacks of sorcerors' work. The Forces of Evil preventing me from playing funk-rock licks through my Fender bluetooth speaker :(
  • ICBMICBM Frets: 73028
    It looks like they have Aux inputs, so what you would need is a 'preamp' pedal - like the Boss/Fender FDR-1 Deluxe Reverb for example, or some sort of Sansamp - and a 1/4" to 3.5mm cable.
