If your primary use is clean sounds, that's a different story - but again, there are better amps for that too.
all true, including there being better clean amps. Must say I would try the Dirty Shirley pedal through the Sportsman first before I sprung for an actual Friedman amp
for me the sportsman is fender based and then season accordingly with pedals
You want good cleans and Marshall OD ?
Tone King Royalist 15w. Lovely amp with a gorgeous attenuator
It has a lovely clean with more than enough headroom for loud home playing but it doesn't sound Fender like when clean
very good but certainly different
Could you go for two cheaper amps with different voicings?
channel 1 is the Buxom Betty clean, which is based of a Fender front end.
channel 2 lots of Marshall tones from early plexi breakup to more modern marshall.
channel 3 - as filthy as my wife
Covers all the bases you mentioned
