This is more HiFi than anything else but the Amps dept seemed the best place
I have a stereo setup which in which occasionally the left channel goes quiet and distorted. At one time I thought the fault was in the o/p stage of the amplifier or maybe even in the o/p sockets: if you powered it off, swopped the speaker leads over and powered it up both channels would work OK, so power down and swop back again, everything is OK so I assumed the LH o/p socket was a bit dirty and having the plug pulled and put back in again cleaned it up. yesterday the symptom occurred again, and was not cured by the aforementioned procedure. So instead of listening to the tuner, I found a CD and whacked it in the player. No problem at all. Ergo the fault is not in the o/p stage of the amplifier. So this time I swopped the L & R channels of the tuner on their way into the amplifier. problem gone away. Swopped back, still gone.
The interconnects between the sources and the amplifier are old, and cheap "string", willing to get some better ones with gold plated phono plugs if doing so solves the problem. Or invest in an aerosol of switch cleaner ...
Do cheap phono plugs corrode and can the corrosion degrade the signal in the described manner?
Maybe one for
@ICBM ?
It's also possible you're disturbing something else inside the amp when you swap the connections, but half-decent interconnects are probably a good idea anyway.
By 'half-decent' I don't mean something that costs more than about £20 .
https://www.amazon.co.uk/gp/product/B003PTVLQK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Those on the system in question must be a few tens of years old!
EDIT: Must remember manners and say Thank you!
