Why does patch cable in fx loop solve problems?!
scarry67scarry67 Frets: 143
Cured problems in both amps today by just putting patch cable in fx loop (Tech 21 and a Session Duette). Both were playing up with volume cutting in & out. Why has this worked? I’m glad it has by the way...
  • John_PJohn_P Frets: 2751
    The jacks on fx loops often rely on the contacts inside the jack, they can get dirty or lose the springiness over time leading to an intermittent connection or signal drop so adding the cable fixes that.
    Yoi could try cleaning with some servisol and push a jack plug in and out a few times - often fixes it.
  • scarry67scarry67 Frets: 143
    Thanks I’ll get some Servisol in there sharpish.
  • normula1normula1 Frets: 640
    Just had to do this on my Lionheart.
    Mine have both been in slightly damp wardrobe for spells when not out and I wonder if that’s got into them. Weird that both have same issue.
  • ICBMICBM Frets: 72770
    Most likely. The usual cause is a tiny spot of corrosion in the FX return jack switch.
