Cornford calamities
McTootMcToot Frets: 2043
edited March 2014 in Amps
It's a Carrera, running either octal or nine pin... Ok. Maybe a bit OTT, but the amp went pop fizz bang yesterday on the 9 pin setting. It had done that before (on the octal) but only when I was experimenting with a very old kt66 that someone had lent me. I switched it off, removed the big bottle, replaced it with a very old Brimar 6v6 and fired it back up: it's been fine since. But yesterday playing on the the 9 pin setting (which was running an almost new JJ EL84). It went bang. Took the back off this eve and had a look at the 84; it was all frosty at the tip and when I tried to remove it, the glass sleeve just came away. It now looks like this: http://i671.photobucket.com/albums/vv73/juleslonghurst/b20ed25b037b5bb127c0bee896dfa1c2_zps7c0eed11.jpg Did I just get a dodgy el84 or should I be asking the local amp chap to be looking at this in more depth? Ta
Beauty is in the eye of the beer holder
My trading feedback  - I'm a good egg  ;)
  • ICBMICBM Frets: 73223
    edited March 2014
    Probably a manufacturing fault in the EL84. From where it broke I would suspect a fine scratch on the inside of the glass from the mica spacer, which then caused a crack.
    It could be that the valve was running massively too hot though, which could have been caused either by a fault in the amp, or - if it has a shared grid connection between the two valves - a fault in the octal valve. (The Mesa Blue Angel is like this and the one I had did that when one of the EL84s shorted - the 6V6 side then ran too hot, even when the switch was set to 6V6 only.)
    Try a new valve, but watch it closely when it's running. If it starts to glow red-hot, you have a problem. If so, pull the octal valve and see if it stops.
  • McTootMcToot Frets: 2043
    edited March 2014
    Thanks John. I need to get another valve in, but might take it up to Henk Philipsen in Horsham for him to have a look. He was the one who lent me a few really old valves to have a play with, including a 50s coke bottle 6l6... Here are a couple of gut shots in case they are of any interest or use... They show where I've removed the 84.
    edited March 2014
    Not sure why they're not showing this time...
    Sorted
  • fastboyfastboy Frets: 166
    I was going to say Jules, take it to uncle Henk and he'll sort it :)
