Any mesa rectoverb (or similar) users on here??
riffpowersriffpowers Frets: 344
A mesa rectoverb 1x12 combo has come up for sale locally, and on paper it looks like it might suit my needs.
Compact, plenty of drive sounds, has a footswitchable solo boost and less knobs and switches than some of the mesa stuff.
It's the series 2 one so can run el34's as well as 6l6's.
I wondered if anyone had used one long term??
Thanks for your patience!!
  • ICBMICBM Frets: 72937
    If you’re still trying to get a Marshall sound, no.
    It also weighs as much as a small car.
  • SidNewtonSidNewton Frets: 665
    I had one years ago. Should have been called the Shitoverb.
    Worst reverb I've heard in any amp and the clean sound was flat and uninspiring.
    This is true - and it has a nasty 'hang-over' when you change channels if the reverb is on.
    The odd thing is that I love the Trem-o-verb, which you would think is similar but bigger since it's based on the Dual Rectifier and the Rectoverb is based on the Single Rectifier. No... the Trem-o-verb is one of my favourite amps ever, but I would need paying before I would use a Rectoverb - they're totally different.
    Of course the problem with the Trem-o-verb is that it weighs as much as a large car :).
  • riffpowersriffpowers Frets: 344
    I'll look out for that . I've also seen a DC5 and a nomad for sale locallish. Just fancied a change.
  • DanRDanR Frets: 1041
    I owned a Rectoverb 25.
    Worst amp ive ever owned.
    Of the two the Nomad is probably going to be more familiar to you. The DC-5 is very much not a Marshall-type distortion, it's more in the Mesa Mark series direction. The Nomad channels 2 and 3 are a little more Marshall-like, to me.
    The Nomad also has a solo boost, which the DC-5 doesn't - but you can use the DC's graphic EQ as a boost.
  • MoltisantiMoltisanti Frets: 1134
    i had a Rectoverb for about 2 days, absolute dogshit, couldn't get a decent sound out of it at all.
  • JeremiahJeremiah Frets: 634
    Aren't there two completely different amps called Rectoverb? An older 50 watt one and the current production one which is based on the Mini Rectifier?
  • StuartMac290StuartMac290 Frets: 1494
    I had a Rectoverb head for a while. It was really mediocre.
  • nick79nick79 Frets: 264
    Yes, supposedly the same pre amp section but different power amp stage. 50w 6l6 (or EL34) v 25w el84.
    Yes. The 25W one is very good. It sounds better and has decent reverb.
  • polotskapolotska Frets: 116
    edited June 2018
    I briefly owned a Recto-verb 25 and wasn’t at all impressed with it, either clean or dirty. It had the feature set I was looking for, but none of the sound I’d hoped for (like numerous other Mesas I’ve owned or tried).
    The Trem-o-verb might be the right Mesa for me, but I’ve always been scared off by the weight and size. I really should try one, though.
  • rockmonsterrockmonster Frets: 846
    Ive had a nomad and both recto-verbs (older models) not good IMHO! Nomad was worse though!
    Tried the Rectoverb last night . I didn’t like it . Very flat and muddy sounding amp that you can Eq.
  • woodywoody Frets: 74
    had a mk1.terrible amp.cleans were horrible. ran the lead channel with bass and mid on zero and treble on ten.it was still muddy and soggy as hell.
  • kjdowdkjdowd Frets: 852
    I had a Nomad back in the day. Loved the sound but it was incredibly unreliable and had an irritating audible pause when changing channel. Not sure whether I just picked a lemon or whether this was a feature
