Stereo Output on Pedals with Wet/Dry
stephen.wood125stephen.wood125 Frets: 217
edited July 2018 in FX
Hi all, probably a stupid question, but then, I am a stupid man, so QED...
If I have something like a rotary pedal/chorus with a wet/dry output and i put one output into the front end input of the amp and the other into the effects loop, will I be able to hear the two sounds without a dual amp setup (obviously I know I won't get the left/right effect as it's a single channel), or is there a different way and I'm being ridiculous.
EDIT: This would be in a Fender HRD.
Thanks,
Stephen
  • jdgmjdgm Frets: 852
    Don't think so.
    What will probably happen is that the signal connected to the amp input will be put through the effects loop.
  • Thanks!
    edited July 2018
    Hang on - I misunderstood what you wrote.  Apologies.
    What you are intending is to make 2 inputs to the amp, one the usual input and the other the fx loop return. Yes?
    Try it; it won't do what you want but shouldn't do any harm.
    I think what will probably happen is that the amp will 'prefer' whatever is plugged into the fx loop return....
    Anyone?
  • Yeah sorry, I shouldn't have alluded to "stereo" I did try to edit the subject line but couldn't.
    Thanks, I will give it a whirl.
  • thermionicthermionic Frets: 9720
    If you plug the wet output into your amp instead of the wet/dry mono output, then plug a spare jack into the other output, what you'll hear is just the wet output. It's a neat way to get a pure vibrato sound out of a stereo chorus pedal.
  • @thermionic thanks a lot, interesting info!  =)
