The original will have been cut for a wound G string. The conversion on the guitar in the photograph makes sense for lighter gauge strings with a plain G.
finding a bridge is easy, or was before rosewood became an issue... but setting it up nicely takes a bit more work, like a nut really.
Instagram
https://www.allparts.uk.com/products/compensated-bridge-and-base-for-arched-top-guitar-ebony
honestly though, chinese sellers on ebay might be worth a look. it will come rough, but no rougher than that one from allparts
like this
https://www.ebay.co.uk/itm/Archtop-Guitar-Bridge-American-50s-Style-Rosewood-Bass-Jazz-Rockabilly-Blues/122954721025?hash=item1ca0ac2701:g:mPYAAOSwKIdaehFp
but straight from the source
https://www.ebay.co.uk/itm/Adjustable-Rosewood-Wood-Guitar-Bridge-for-Archtop-Jazz-Guitar-Musical-Parts/152822483079?hash=item2394ee0887:g:IkAAAOSwdJ9aRttO
i would buy 3 from china, pick the best one and give it a good oil and polish
Instagram
https://www.ebay.co.uk/itm/Wooden-Carved-Guitar-Bridge-for-Archtop-Jazz-Guitar-Accessory-137-x-15mm/162916709890?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D52945%26meid%3D5b3cca21d70b4079a82afcd5802857c1%26pid%3D100005%26rk%3D4%26rkt%3D11%26sd%3D122954721025%26itm%3D162916709890&_trksid=p2047675.c100005.m1851
I like your idea of getting a couple. I’ve got Höfner bass bridges from China in the past and they were perfectly acceptable.
And definitely don't use a plain third... it's just Not Right
Lovely guitar, with a vibe that's completely different from a modern electric.
Is there any way to reliably date this? Store said they thought '61 but there are no obvious markings to ID it and pots aren't available to view, maybe a dental mirror?
If there's no serial number visible, there may be a 'factory number', which will usually be on the inside of the body near the treble-side f-hole, often on the inside of the top so you will also need a mirror. The letter in it is the year, Q is 1961 but they go backwards!
The knobs would make it 1961 or earlier, but they could easily be replacements.
https://www.ebay.com/itm/Gibson-1959-Tortiose-Shell-Single-Pickup-ES-125-Pickguard-w-Mounts/202365031495
Instagram
https://www.ebay.co.uk/itm/Gibson-1959-Tortiose-Shell-Single-Pickup-ES-125-Pickguard-w-Mounts/202365031495
Happy days
