Old & cheap and suitable for bass?
BridgehouseBridgehouse Frets: 24581
I’m on the lookout for a low wattage small all valve head for bass - mostly for recording hence volume doesn’t matter too much.
Before I consider one of those pricey Ampeg jobs, can anyone think of an old one that I may be able to get hold of cheaply that would do the job?
  • ICBMICBM Frets: 73030
    Almost any small valve amp and a bass cabinet. There's very little difference, if any, between low-powered amps designed for bass and ones for guitar.
    Any particular ones that might do a better job than others? I’m looking for super simple - gain, tone, master.
  • steamabacussteamabacus Frets: 1276
    I've used an old Selmer Treble 'n' Bass for this in the past.
    These days I have an old valve Hacker 'stereo hifi' extension speaker (probably 5 watts or less?) which I've modded with an external speaker socket and run into an old 1x15" cab. Very simple - on/volume, bass, treble - and sounds very warm and retro. For more flexibility I can run a small mixer into the Hacker's input.
    The second pic was the bass players setup (believe it or not) for an ambient looping trio recording project a few years back.
    Literally any old valve amp. You won't get a master volume, just volume and tone or treble and bass. The limiting factor for bass is the speaker, so just disconnect that - if it's a combo - and run it into a bass cab.
    I shall start trawling the bay and see what pops up
  • jpfampsjpfamps Frets: 2738
    One of the best bass amps for recording is the GEM Mars 30.
    This is a flip-top amp, with solid state front end and valve power amp (2 x EL84s).
    Might take a bit of searching for but, are cheap.
  • pintspillerpintspiller Frets: 998
    When I started recording demos on my four track about thirty years ago I just plugged the Line Out of my practise amp straight into the board. I think it was a Ross Fame 10. The bass parts sounded much better than the guitar parts.
  • JezWyndJezWynd Frets: 6171
    I used a Laney Cub 10 combo which worked fine for bass but I've upgraded to an Ampeg PF20T which has the useful ability to DI out to a desk or whatever without needing a cabinet attached. I've never tried using it in that scenario but apparently it works fine. The Laney has a simple Volume, Tone Gain setup and can use an external speaker. I fed it out to an Excelsior cabinet with a low wattage 15". Worked great for home use.
    Great suggestions all - keep em coming!
    If you are interested, I can do the Laney for 120 delivered. It's sat on the shelf unused since January.
    If it was a head I’d be all over it - but I have a 15” cab for it to go on...
    I had an old GEM combo once - a similar hybrid amp, with reverb and tremolo.
    If you turned all the knobs up full it sounded exactly like the guitars on Ennio Morricone western soundtracks.
    Thought I’d revisit this - found a shop doing the Ampeg PF-20T on special and bought one. Dunno when it’s going to arrive but I’ll let you know what I think - was cheap, and it’s a proper small wattage all valve bass head with transformer DI out...
  • DrBobDrBob Frets: 3020
    Rarely, has a description made me want a piece of guitar gear so badly !
    In that case, the model to look for is the Venus GR20. Unfortunately it seems much rarer than the non-reverb G20 version...
  • brooombrooom Frets: 1178
    edited August 2018
    I'm selling a 65 amps apollo, which is based on an ampeg portaflex with a dash of SVT. Two 6L6s and rectification so about 45/50w, perfect recording amps for bass.  All handwired, and really high quality. Not sure if that's what you're looking for. And it's now quite cheap.
    If I hadn’t just bought a PF20T... how cheap is cheap?
  • martmart Frets: 5205
    http://thefretboard.co.uk/discussion/126080/65-amps-apollo-cab-1966-deluxe-reverb-magic-amps-x-brit-vintage-marshall-jmp#latest
    Looks lovely - it’s slightly more than I budgeted, and I’m glad I got the PF20T at £299 - but your 65 Apollo looks real tasty!
    It's a great amp, I used to play bass a lot. I've stopped a bit, not sure why. I still love the idea of grabbing a precision and thumping down some simple bass lines.
    The combination of 6L6s and 6sl7s octal preamps tubes with the baxandall tone circuit gives it an unmistakable ampeg sound. Thanks @mart for pasting the sale link.
    @Bridgehouse enjoy the new amp.
