Soldered pedalboard cables? suggestions...
Hey guys, gonna make up some soldered cables for my board changing from 10+ years of solderless ones, anyone recommend some good cable and jack ends? standard neutrik ones look alittle too bulky i think. Looking at mogami 2319 for cable i think. Any thoughts or experiences would be welcome. cheers!
  • simonksimonk Frets: 1467
    Hicon Pancakes and van Damme cable will get the job done and not cost the earth. designacable.com stock both and will make them up for you.
  • ecc83ecc83 Frets: 1658
    Cable type hardly matters so long as it is rugged and easy to work with. I would avoid anything with the greasy ***t "anti-microphonic coating.
    Tips for the pancake jacks. Scrape/file off the bright plating at the solder points, it makes them much easier to solder. If they use those tiny screws, use a dab of 'er nail varnish on the threads or heat shrink. Better both!
    Dave.
  • GagarynGagaryn Frets: 1553
    Worth considering that pancake jacks can be problematic on pedals where jacks are very close together - looking at you Strymon! For other purposes though they are pretty good - @ecc83 advice is worth heeding re the screws. And don't drop the screws - looking for them is no fun!
