I have finished this Bass but thought I would post some build pictures
The body shape is heavily influenced by the Ritter Raptor Bass.
Scale length 34"
Top Sycamore ? slightly rippled
Body Ash
I think the top is sycamore. It was bought nearly 3 years ago and I can't find any receipts for it.
I draw another outline about 4mm away from the body shape by using a nut or washer as a guide with the pencil inside. This will be the
line I cut to with the band saw.
Pilot holes were drilled then using a 16mm bit drilled 2mm or so into the back of the body so when the relief holes are drilled using an
11mm bit, there would be no tear out
My router bit is 12.7mm, after reading one of GSP' post I bought a 20mm and 15mm bearing, so I could trim the body down in stages.
I used the shaped waste parts of the body and template to act as a support for the router, which is particularly useful when doing the horns. The mdf was stuck to the Ash with double sided tape, and after I had routed 3/4 of the sides I flipped everything over then used a bottom bearing guided bit to finish off.
Some relief holes drilled out before hollowing out the 2 sections, and I have also drawn in and written on the body where to route for the pup wires, as I forgot to do this on my previous build and had to drill the holes through the pickup cavity using a 20" bit because of the angle.
Remembered to route the wiring channels before the top goes on. And some chambering to reduce the weight.
Neck and Body 90% completed,
Very nice.. The way the top figure flows looks great.
That would make a cracking fretless
I just wish I could stop seeing the thread title as Sea Bass...
It is a great tip
I said maybe.....
