I have one of those little Boss BSB-30 pedal cases with 3 pedals in it; a PH1r phaser, BD2 blues Driver an a DM2W delay. It's a great little setup which I use for jams and as a back up to my main pedalboard, should it go pear shaped at a gig.
Anyway, Id like a tiny power supply that can power the three pedals, but is small enough so it can fit in the top corner of the box when it's shut. I tried a Daisy chain with the Roland 9v 500mA that came with my micro cube, but there was tons of noise, especially with the bd2 on with some gain. I also tried with an old Zoom power supply with the same result. I was a bit surprised at this as all the pedals are analog, but that's what's happening.
So does anyone have any recommendations (other than using batteries, which I'm currently doing) on power. I'm thinking a One Spot might work but I'm concerned about doing the Daisy chain thing given my experience so far.
R.
Eqd Speaker Cranker clone
http://www.hotroxuk.com/warwick-rockboard-power-lt-xl.html?utm_source=GoogleBase&utm_medium=organic&gclid=EAIaIQobChMIhaWp7f3n3gIV1oXVCh0Z3Qm5EAkYAiABEgJDFfD_BwE
In that case, I'd add a Gigrig ACA AOK adapter, either directly from the raw power or possibly from the Isolator (current requirement should be low enough to work).
Although, that rather bumps the price up, when a simple mod of the pedal would fix this issue.
R.
Personally I'd rather use a daisy chain than modify a PH-1r (and I do), what you're doing should be fine. A 1-Spot would also be fine, maybe even overkill.
If you need all that Gigrig gubbins for such a simple setup then something is wrong somewhere.
https://www.breakthemachine.co.uk connect@breakthemachine.co.uk
Both powered 6 pedals through a daisy chain no problem.
