Compressor after drives?
builttospillbuilttospill Frets: 463
Anyone tried this? I think it sounds really good
  • For a heavy drive I feel like it wouldnt really be doing much..the drive is already compressing the signal
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Yes. Works for me....
    Fat General after Duellist...
  • BeexterBeexter Frets: 620
    Yep, after drives is where my compressor goes. It means I can still clean up the drive from the guitar.
  • mgawmgaw Frets: 5321
    same here compressor after drives
  • LewyLewy Frets: 4372
    edited February 2019
    Yep, always after drives. When you roll back the guitar volume, your drive cleans up but your volume doesn’t change as much.
  • VoxmanVoxman Frets: 4788
    I put my compressor before the drives.  My pedalboard follows this approach:
    https://www.strymon.net/setting-up-your-effect-signal-chain/
    But as stated, there is no 'wrong' way to set up your pedalboard and different approaches give different sonic results.
  • SassafrasSassafras Frets: 30320
    Never. It just strangles the sound and compresses far too much for my liking.
  • CirrusCirrus Frets: 8497
    I'd say it just depends. With longer attack settings on a compressor, if you're playing a riff that's quite staccato, you can use a compressor to add transient punch at the start of notes - the longer attack makes it more dynamic *with* the compressor. Also, compression after extreme EQ, so, say you wanted to run a drive pedal really scratchy and bright, tends to soften the extremes of the eq.
    But that's all just a hypothetical, I've never ran compression after drive because practically, I've never seen the point.
  • Great replies all!
  • ESBlondeESBlonde Frets: 3611
    Compressor after everything for me on my main board. Only subtle use that way.
    My rehearsal rig (carrier bag of bits) has an MXR Dyna comp which I run last in the chain too, but that is a lot more aggressive in ratio and attack and isn't 'always on'.
  • Depends on the compressor. In terms of handling a hot input signal I haven’t come across anything that touches the API Tranzformer. It always feels like it has more headroom in reserve. By comparison a regular MXR/Dynacomp circuit will reach its limit fairly quickly depending on what you use before it.
  • Before for me.
