Sold Delay & Chorus Effect Pedal - handmade in the UK by BIG ZED - DEEP SPACE
RevMattRevMatt Frets: 848
edited March 2019 in FX £
Now Sold
Here's a superb pedal from boutique UK builder, BIG ZED.
It's the DEEP SPACE pedal which combines 3 functions into a single unit not much bigger than a standard single FX pedal. These functions are:
- Delay - the front left switch activates the delay effect which is set via the 3 blue knobs (Echo, Mix, Delay)
- Chorus - the front right switch activates the chorus effect (the LED pulses to show the speed of the chorus!) - this is controlled by the 2 green knobs (Pulse, Depth)
- Buffer - the upper centre switch is like a master switch that can activate the whole pedal regardless of how you've set the delay and chorus switches - this master switch also selects between true bypass or buffer, so when active it's in buffer mode and the delay and chorus switches are live
It includes a number of other cool design features too, for example, the LEDs are red when in standby or bright blue when active. In addition to the normal in/out and mains socket, there's scope to add an expression pedal.
Please note, to maximise perfomance, these are not designed to run off a 9v battery and you will therefore need to run it from a main power supply (a standard pedal power supply / brick type unit works fine).
Plenty of info is available here:
http://bigzed.co.uk/?product=deep-space-chorus-delay where you'll see these sell for just shy of £150. Offered here at a bargain price due to me getting a good deal when I bought it.
This is only a few months old and barely used, so apart from the velcro on the base, it's like new. It comes with the original box and instruction letter.
Price: £60 (plus £4 if posted)
