Anyone got 2 feet of speaker cable going spare?
monoaminemonoamine Frets: 506
Need it to go from my make-shift L-pad attenuator to the actual speaker in my little Fender Pro combo...
Can't bring myself to spend £10 on a proper cable to only cut it short!
Cheers
Andy
1979 Tokai TE-85
1980 Tokai LS-80
    What kind of quality do you need?
  • monoaminemonoamine Frets: 506
    low quality... anything that can handle the kind of impedance/current etc between amp and speaker
    1979 Tokai TE-85
    1980 Tokai LS-80
  • digitalscreamdigitalscream Frets: 28097
    Chop up a mains cable, surely?
    <space for hire>
  • GIJoeGIJoe Frets: 213
    edited April 2014
    I could dig you out a bit, but mains might be quicker!
    Edit - the electrons don't go faster!  Quicker for you to have a finished cable :p
    "Nobody is really researching robot jokes"
  • vizviz Frets: 11041
    Make sure it's orange as per tradition. Old lawnmower should do.
    oh i thought speaker cable had special capacity to hold the impedance or something, which is why you shouldn't use a normal guitar-to-amp cable...
    might be having a moment here!
    1979 Tokai TE-85
    1980 Tokai LS-80
    Nope just anything twin core and thick.
    interesting... ta for the help gents
    1979 Tokai TE-85
    1980 Tokai LS-80
    No, it's the other way round - instrument cables are shielded (to prevent hum), which can cause problems when used between an amp and a cab.
    <space for hire>
  • mrn1989mrn1989 Frets: 240
    I've got some, cover postage and I can send some if you get stuck
    Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
    cheers fella, will try the mains cable first and send smoke signals if i run into trouble :)
    1979 Tokai TE-85
    1980 Tokai LS-80
    edited April 2014
    :) Message me if you need some, I might not see a reply in the tread, just so you don't think I'm ignoring you ;)
  • LodiousLodious Frets: 2013
    It's not a problem with the shielding, it's the current capacity of a instrument cable isn't great enough for use as a speaker cable.
