1Meg pots do not sap quite so much high frequency detail.
CON
The resistance taper cuts very sharply, rendering the pot little better than an on/off switch.
By all means try them. You might like what they do almost as much as I dislike them (except on Fender Jaguars).
(formerly customkits)
1M is probably not a great idea though - it not only increases brightness, it gives more treble loss as you turn down. The Fender Jaguar has an extra resistor on the tone control to make that less obvious if the tone control is below full up.
