Mine currently reads 46%, which is pretty much ideal. Most of the year it's reading 55% or over and rarely gets close to 40%.
If you are in the UK, where the air is relatively damp, and don't set your central heating ridiculously hot, then it's highly unlikely to be a problem.
The big issue is relative humidity. When the air is really cold outside, it cannot contain a lot of water vapour. When it comes inside and is warmed up by your central heating then it still has the same absolute moisture content, but the relative humidity is much lower. The more you warm the air up, the lower the relative humidity will get.
If you keep your central heating at 25C then you might get problems as your relative humidity will be significantly lower than at 20C. If you live up in the wilds of Scotland, and it is 5 degrees colder outside, that could cause problems, but in England, with a sensible setting on your central heating, it shouldn't be an issue.
In fact, case humidifiers can leak and cause a much larger headache.
I’ve had my hd35 and j45 our and about in the living room with no ill effects whatsoever
Re case humdifiers. Yeah, great idea to stick moisture inside a guitar case in the UK. I once heard Martin Simpson tell a great story about a guy who destroyed a Sobell doing this: warped the top +++
42% shouldn't cause any problems.
The Taylor site says that the ideal relative humidity is 45 - 55%:
https://www.taylorguitars.com/support/maintenance/symptoms-wet-guitar
I've seen other articles that say ideal humidity is 40 - 50%, so 42% is in that range.
in the meantime - Ive stumbled across Mike Dawes and Ernesto Schnak
