I know this is a very specific request, but I have a 90's Jackson with a Takeuchi TRS-101 Floyd Rose bridge, that came with a replacement arm which is quite ill-fitting.
I'd like to find a better replacement that fits properly... it appears to be a 6mm screw-in type arm, but the screw-in part that inserts into the bridge is unusually long, which means the standard replacements with shorter inserts will keep screwing in until the arms starts to bang into the fine tuners at the back. If I stop early then it's a very loose fit, which is terrible for subtle warbles etc.
I've searched online extensively and the only replacements I can find are originals, which cost stupid money for what it is. Does anyone happen to know where I can source a replacement that doesn't cost the earth?
Here's a diagram of the whole system:
https://www.axebition.com/sites/default/files/documents/trs-101-diagram.png
It's not an expensive guitar so if it comes down to it I can just wrap some tape around the insert and risk gunking up the threads, but just wondered if there was a better solution.
Anyway, I’ve found a temporary solution. I cut a small section off the end of a thick bamboo skewer I had lying around (I knew it would come in useful one day ) and dropped it into the arm socket. It seems to raise the height by just the right amount, and I can even adjust the tension now using the screw at the back of the unit. Plus it’s pretty snug in there so it doesn’t fall out when I remove the arm.
I think I’ll leave it like that for now and see how it holds out.
Now on to shimming the nut...
So Far, so Good.
However, in spite of the arm A being threaded on its inner end, there's nothing for it to screw into. So it just sort-of floats about vaguely and indeed, comes out of the base quite readily if you give it a tug. What gives? How's it supposed to stay put? Or is it supposed to come out so easily?
Any info on this aspect of an otherwise excellent trem. unit would be appreciated...
