Hi all,
I'm looking for a delay with the ability to give me tap-tempo function, preferably with an external footswitch. The ability to have a second exp. out to control mix would be great, but not essential. Not looking for crazy, extensive delay time or even stereo options necessarily, just the best sounding, most functional and well-built delay. Analog tones aren't really required as I have my beloved Carbon Copy for that. True bypass would be ideal although the option to toggle between buffered and true bypass would be even better. Looping for home practise would be a bonus. As far as I can work out, the best options are the Boss DD7 and Hardwire DL8, though both have their downsides, notably the Boss 'tone-sucking' in bypass mode and the DL8 not having the ability to use external expression/tap tempo switches. Hopefully you can help me out!
Thanks,
Jack
Otherwise, @bidley is on the money, t Rex stuff is awesome.
For clean repeats, the Providence Chrono is a good choice, and the Timeline (I am finally reluctant to admit) can virtually do the lot...
"Nobody is really researching robot jokes"
Jack
My favourite digital delay with tap that's not stupid money is the Hazarai Memory Man. Construction is dogshit, in my opinion, though. Good old EHX.
Hi Jack, tonal quality and build on TRex Replica destroys TC, it just looks boring.The Nova and Repeater are cool if they are on all of the time or in a loop as they they quite a bit of your signal.
Does what it's supposed, tap tempo on the front and, unlike so many, is easy to understand and use. I power mine with the mains supply that came with it.
dunstanmus - "they they quite bit of you signal" is the second they meant to be a rob or distort? Personally, I find the TCF totally transparent where ever I've put it in my rig. Is there something unusual with your gear?
I'm torn between the Nova Repeater and Nova Delay. I think the display on the ND could prove very useful.
