Hudson Broadcast - 24V single-switch - Regent Sounds Limited Run - £140 - SOLD
Boxed, barely used. Free postage.
Details:
The BC-24V-LTD takes this classic transformer-coupled, discrete Class-A germanium circuit, this time running internally at 24 volts from a standard 9 volt supply. The increased voltage gives extra headroom and a tighter low end – fantastic if you are looking for a little less saturation and grit, but without losing that unique sound of the Broadcast. The BC-24V-LTD also features a three position gain switch offering MID-LOW-HIGH modes. In LOW mode, the pedal has most headroom and stays nearly clean across its range, whilst retaining colouration from its germanium circuit and transformer – perfect if you use higher output pickups, baritone, bass or keyboards . The MID mode is voiced to sound and behave as the regular Broadcast – still pretty clean but adding more grit and saturation to the mix. In HIGH mode, as with the regular Broadcast, the BC-24V-LTD heads into overdrive, distortion and fuzz but with a slightly tighter low end. Maximum gain in HIGH mode can be adjusted to taste, using the internal trimmer.
![](https://imgur.com/U6widml)
![](https://i.imgur.com/U6widml.jpg)
![](https://i.imgur.com/kNk9ngs.jpg)
''i've not seen a reaction like that in here since George Best got kicked out for glassing a bouncer''
