In contrast to Rickenbacker's V-series, the C-series, including the Rickenbacker 360-12c63, is much closer to the 60s original:
The construction of the body is particularly specific:
"X-Bracing" inside this one as opposed to the sustain block.
Due to the x-bracing the guitar, played unamplified, is clearly louder than the instruments with sustain block.
Also the used screws and the bridge are from the 60s. Original model.
Rickenbacker toaster pickups which are factory installed.
The guitar is immaculate apart from one small blemish on the body, near the sound hole
£2900
